m5odr2
No rebuild kit will strengthen that trans.
What kind of use are you talking?
A T5 might be rated for up to 300 HP in a Mustang, but you are going to be 1000 lbs heavier, so hard use is going to be an issue with a T5.
T56 will solve your problem:
Modern Driveline T5 transmission parts & conversion packages
So the M5ODR2 is the Mazda 5-speed, overdrive high-gear transmission in the V6 manual trucks? I doubt you will need a 'stronger' box. What is the new engine out of, or is it a crate engine? I'd guess I would go with the 3.55 rear or even lower. Your truck probably has the 3.31 which is pretty high.
It's a crate engine. I just worry that transmission won't hold up with a more aggressive clutch than the stock one.
timothy47129
02-08-2017 01:22 PM
Newfiestang50
17
08-29-2016 06:25 PM
blueeyedfordguy
03-01-2010 09:44 PM
79 Trailer Special
02-20-2004 07:46 PM
