what power adders have used on your gas truck and with what results
I was using 42lb injectors back then, but the datalogging software i was using doesn't display % injector duty cycle. What I can tell you is with the 42's, I was seeing a little over 50psi of fuel pressure, at WOT, and I wasn't using an FMU at the time.
The datalogger for the XFI i'm using now does display % injector duty cycle, but I don't have a saved data logs of it and I don't remember what those values are. Still running about the same fuel pressure and no FMU.
With my new combo, the fuel system still operates the same except that I have replaced the factory in-tank pumps. Now I have 255lph pumps in the front tank, rear tank and the inline.
sounds sweet. If I weren't eliminatING my front tank I would do the same thing. I am going to buy a new rear tank and a sump kit. When I am on the rear tank selection I will have just the internal pump. On the front selection I will be running both into the an-8 line and stock return. This will be after the stroker and blower goes in. But I am a bit torn I just got my hands on a stainless hot side for a fox body. I bet dollars to doughnuts it would bolt up and work with my 94.
My phone won't let me. Grrr I will watch it later tonight. I started rounding up the parts to put this blower on the f150. Guess I will need to buy s set of .060 forged pistons. I know that's the theoretical max bore. But if your going to use stock gt40 3 bar heads. (if I can find some) going to need some diameter on the piston to unshroud the valves and create more vacuum at the same time as pull more boost into the cylinders.
I contacted vortech about rebuilding this blower they won't do it Because the serial tag was removed from the gear case when it was polished. So I I got ahold of "sales@superchargerrebuilds.com" they quoted me $420 for the rebuild. But I think I am going to throw some seals at it and see what happens.
#28
#30
Thanks, I'm happy with it,runs great. No dyno time, been tuning it myself. Prob make a pass down the 1/4 at some point.
Here's the turbo: http://www.ebay.com/itm/Borg-Warner-S366-Turbo-S300SX3-66mm-Turbo-91-A-R-AirWerks-BRAND-NEW-/181754658858?hash=item2a516c002a&vxp=mtr
