I have a 96 F150 6 cyl 4.9 Auto trans. Owned it for a few years, use it sparingly for a work truck. Recently it will not start after getting hot. Runs fine warming up. Turns over fine, good batt and starter but will not start? Any ideas?
I'm kinda going through that now with my truck. New ECT, IAC, newer plugs, wires, cap, rotor, cleaned throttle body, new O2 sensor, new fuel filter, new injectors.. It still has a heat soak issue. I'm gonna do pumps next and that should fix it. It just cranks a lot longer when warmed up.
Found the Problem. After everything pointed to the Fuel Pressure Regulator I changed it out. Still the same Problem. On YOUTUBE a guy had the same issue. The Temp control sensor. $20.00 at Autozone, starts and runs great now. I was about to change out the fuel pump! AHHHH!
