351w Intake manifolds
Does anybody have a good brand for intakes and any advice for trying to open up the air intake system for my 5.8L. Ive been reading some of these forums and just see that edelbrock isnt the route to go. SO I need some advice from someone with experience with this. Thanks~
on
Edelbrock makes a several different versions, as does Trick Flow, and then there are several offshore brands. All of these will outflow the stock intake by quite a bit and all except the Edelbrock truck version use a single throttlebody. I have a new unused Typhoon intake for sale if you are interested, pm for details.
They claim idle to 6800, but im thinking more like 1500-6k. Found a comparison one time, made more power than the performer and the same power lower as the performer rpm. For a truck i would not run a single plane.
I assumed that you have a carb. If youre efi, theyre isnt much choice, i think you can port the lower and use a trick flow upper for good results.
'89F2urd
04-03-2015 03:58 PM
Wild Karrde
08-27-2007 09:21 AM
