1959 T-800 spec tag decode
T series is an F series with tandem rear axles.
T80 = T800.
F = 332 4V
9 = 1959.
U = Louisville KY Assembly Plant.
33713 = 1959 Numerical Sequence of Assembly, the trucks specific serial number.
175" Wheelbase.
R = Red.
T82F = T800 w/hydraulic brakes, 43,000 lbs. GVWR
27D = Assembled April (D) 27, 1959.
QK: Q = Spicer model 5831-B 3 Speed Transmission / K = Clark model 265V 5 Speed Direct.
16 = 8.60-1 ratio; T-800 = Eaton model 34MF forward rear axle; Eaton model 34MR rear rear axle. Both: 34,000 lbs. Rear Axle Capacity.
43,000 lbs. Gross Vehicle Weight Rating.
187 net HP @ 3,600 RPM
T80 = T800.
F = 332 4V
9 = 1959.
175" Wheelbase.
R = Red.
wyomingford
05-28-2017 11:22 AM
Tomc750
01-06-2009 06:27 PM
