Atlas pinnacle shingles? Experience ?
How frequent are the hail storms around you? My personal recommendation is Rubber environmentally friendly roofing products! -
Around here we are getting more and more frequent hail storms and these euroshield rubber roofs are the ones being installed more and more as well. You're insurance probably won't cover the complete cost of these as they are more pricey but if you can cover the difference you won't have to re roof after the next hail storms roll through.
google "atlas pinnacle shingles complaints" or ".....problems".
This one is a pretty good exchange:
Problems With Atlas Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
I was going to talk about my satisfactory roof experience with a roof installed in 2002. Some problems with the install, which I will have to deal with. But the shingles lived through a "100 year" storm here where we had at least 70 mph gusts. So I go to search for problems as I did with the Atlas stuff. Turns out my roof might be the subject of a class action!!!!!
I gotta go dig through all that stuff from the remodel! GAF Timberlines fwiw.
Wouldn't you know if I did have problems I might in line for money or a new roof. Since they are fine.....Oh well.
Go with a National brand: CertainTeed, GAF, or Owens Corning.
Regional brands like Atlas, TAMKO, or Malarkey (yes, seriously) are cheaper and use gimmicks like ScotchGard to sell to unwitting customers.
Disclosure: I am a distributor for commercial and residential roofing products.
Jason
The product that you have mentioned twice is only available in Canada.
Here is an alternative: Gerard USA Metal Roofing | Premium Stone Coated Steel Roofing Systems
or http://www.davinciroofscapes.com/
Or hail resistant asphalt aka IR = Impact Resistant, available from the national brands mentioned above.
Hail storms happen in the Midwest, but it's not like they're often. It takes a pretty serious hail storm to damage a roof (probably at least grape-sized hail stones or larger), and those are quite rare. I'm about 3 hours SE of jake00, and in my almost 20 years of home ownership, I have yet to have hail damage. It's been close a couple times, but the hail portion of a storm tends to be confined to a small area.
Not to mention, there's the cost issue. The average length of ownership of a house is 5 years. A vastly more expensive roof product won't necessarily add enough to the value of the home for the seller to recoup their costs when they sell the home in a few years.
Jason
Jason
Jason
Ridge vents have to be cut in where there were none, ice and water shield must be applied appropriately and the correct number of nails per shingle must have been used and it must be installed over clean roof decking.
In the case of the GAF Timberlines, the warranty is transferable provided that your installer is GAF certified and you have all the documentation proving when the work was done.
