'57 F100 need 1/2" longer wheel lugs
Old 04-15-2015, 12:07 PM
mgargiullo's Avatar
mgargiullo
mgargiullo is offline
mgargiullo is starting off with a positive reputation.
I swung past Advanced Auto on the way in to work this morning to see if they could help me find wheel lugs that are 1/2" longer than the stock lugs. I should have known it was a pointless exercise.
I'm pretty sure standard lugs are 1/2" x 20, but I don't know how long... I just know I need them 1/2" longer to use the wheel spacers.
Does anyone happen to know what I should ask for at Napa?
Old 04-15-2015, 01:20 PM
307-Niner's Avatar
307-Niner
307-Niner is offline
307-Niner is starting off with a positive reputation.
Old 04-16-2015, 09:19 AM
mgargiullo's Avatar
mgargiullo
Well... I was able to order some from NAPA... at $7 a piece. Wow. After searching Dorman's website, I found one with very similar dimensions to what I needed. Turns out, a 2009 Ford Taurus wheel stud is the same specs, but just a little longer.
Old 04-16-2015, 10:36 PM
Htchevyii
Htchevyii is offline
Htchevyii is gaining momentum as a positive member of FTE.
Glad that you found something. I have done parts for 23 years. Many times, a longer substitute can be found by dimension, as you have found. Unfortunately, most of the chain stores just look in their computer and give up. It's not all their fault, the printed buyers guides are pretty much a thing of the past and they usually don't have access to the internet in the cooperate stores. Napa's usually have more experienced parts people, although their walk in prices aren't the best.
fordtreexr
20
09-07-2016 05:42 PM
Reef Tech
1968-2013 Full Size Vans
10-24-2014 11:15 AM
hooperdoski
07-29-2013 05:18 PM
macguy
6.7L Power Stroke Diesel
06-29-2012 09:26 AM
JW 4x4
04-23-2002 02:05 PM
Quick Reply: '57 F100 need 1/2" longer wheel lugs
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
