5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
2015 F-150 5.0 Oil Capacity
Old 04-15-2015, 11:16 AM
mantta's Avatar
mantta
mantta is offline
Question 2015 F-150 5.0 Oil Capacity
What is the crankcase oil capacity on the 2015 F-150 5.0 engine? The owners manual says 7.7 quarts and the Ford website says 6 quarts. What is the correct amount? Thanks!
Old 05-04-2015, 09:38 PM
sky Cowboy's Avatar
sky Cowboy
sky Cowboy is offline
Mine takes almost 7.5 liter, and i think a quartnis just small....so ahout 7.7 should be close. ...it takes way more than 6 for sure.
Old 09-29-2015, 04:02 AM
DaveyMac's Avatar
DaveyMac
DaveyMac is offline
7.7 quarts
Old 10-13-2017, 08:00 PM
c_rossman's Avatar
c_rossman
c_rossman is offline
I put 8 in mine and right to the top of the hash marks on the dip stick
Old 10-14-2017, 03:20 PM
92F350CC's Avatar
92F350CC
92F350CC is offline
It's definitely 7.7
Old 10-17-2017, 11:12 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
Would it be horrible if one puts in 8 qts? Would it upset the counterweights that have been carefully shaped to minimize oil slinging?
Old 10-17-2017, 06:35 PM
sky Cowboy's Avatar
sky Cowboy
I personally wouldn't do it.
But it is unlikely that such a small amount over full would hurt anything.
The main culprits for an overly full crankcase are lack of air space for the pumping forces of pistons, so it can build up excessive pressure...and possibly blow seals. Also the crank throws can both froth the oil making it have excessive air bubbles etc...and its robbing power and increasing fuel burn if the crank has to slosh through the oil too much.
But again my uneducated guess is that overfilling such a slight amount likely wouldn't cause severe damage.
But I do not understand over filling on purpose.
That said I just slightly over filled my car yesterday by accident doing an oil change on it. I just drove it as is, but it is barely over, maybe 100 ml too much.
Old 10-21-2017, 10:41 AM
DevilDog556's Avatar
DevilDog556
DevilDog556 is offline
8 quarts put it at the "full" mark on the dipstick ('17). I owned a Subaru WRX a while back whos manual stated 4.4quarts but the dealers always did the full 5 and never indicated overfill...odd.
Old 10-21-2017, 11:33 AM
sky Cowboy's Avatar
sky Cowboy
Some times there are also 2 different amounts of oil required listed.
With oil filter change, and without.
Confuses me, because it is stupid to not change the filter as well in my opinion. But it makes a difference for sure.
vagent
2009 - 2014 F150
16
12-12-2017 06:02 PM
mantta
2015 - 2020 F150
03-28-2015 05:08 PM
Truckpilot1329
2009 - 2014 F150
10-24-2014 01:09 PM
BigBlue92
06-22-2011 08:32 AM
John7894
01-21-2005 06:28 PM
Quick Reply: 2015 F-150 5.0 Oil Capacity
