1989 F-Super Duty Headlight Problems
Im working on a 89 super dutys headlights. Driving down the road they will be on then flicker and go out and come back on after a bit. Ive replaced the dimmer switch, headlight switch and a big boxy relay under the hood on the drivers side attached to the fender. What else do I need to look for to stop this?
start with ground wire connections
Now work on connections in your power cables, junction boxes including any on the bulkhead. Look for frayed wires around cable ends. Google fitting headlight relays, these articles have great info on cable runs vs voltage loss vs headlight output.
1968 F250camper
15
10-29-2017 08:21 AM
1966f100ranger
12-09-2016 01:10 PM
joners
05-05-2004 05:20 PM
