1999 Lariat not starting, blown fuse?
Hey guys, I have a 1999 F150 Lariat 5.4 that's been sitting for a few weeks waiting for a new MAF. Finally got a MAF from a junkyard (out of an 01 Expedition) and installed it.
Turned the key, cranks once, then I hear a loud click and then just continuous clicking. I did some research and people are saying this is just the starter solenoid and that the battery may be dead. I charged the battery a couple hours and waited until it showed 11.some volts, tried to start it again, didn't even turn over, just clicking. I also noticed the theft light blinking rapidly, but if it were the PATS acting up, wouldn't the motor at least turnover?
So I went back to charging the battery. Went out a couple hours later (at night), and when I opened the door, none of the lights came on. Then I hear a click, the lights come on, followed by another click, and the lights went off. This happens each time I open and close the door.
So did I potentially pop a fuse? Or is my battery just fried? Would replacing the MAF with the newer one out of the expedition cause any weird issue? I doubt it, but anything is possible at this point I guess.
Any other ideas?
Thanks guys.
Any other ideas?
Thanks guys.
Well I'm sure hoping that's not the case because then I'd be 2 for 2 on vehicles needing batteries replaced this year, but we'll see tomorrow.
So why would there be a click from the dash before and after the cab lights went off/on? I've dealt with plenty of dead batteries before but this has been the most strange (and noisy).
Until you have VERIFIED the battery, connections, and cables, you're just guessing.
Perform the tests so you can either rule those possibilities in or out and then go from there. I learned a LONG time ago that if you didn't have proper power and ground, nothing else mattered so I was trained to ALWAYS test them first.
I'm not saying it isn't the battery, even though I haven't had the opportunity to check (taxes and rain getting in the way), I was just curious about what the click may be.
And yes, I understand getting lights even with a weak battery.
If it weren't for all the clicking I wouldnt even be asking, I'd go straight for the battery. I mostly was just wondering if the clicking could mean something else, or if they were normal with a dead battery.
Unfortunately the truck was sitting where I couldn't get another car to it to jump it. But I cleaned up the terminals and charged it to a full 12v and... nothing. So 1 new battery later it was on the road, and running wayyyyy better than it did before with the new maf, so I'm pretty happy.
Now I just need to fix the heater, brakes, and exhaust.
Thanks for all the input guys
Rattlesnakebyte
Electrical Systems/Wiring
01-29-2016 09:52 PM
babstinger
1997-2006 Expedition & Navigator
09-06-2010 06:44 PM
Darren_C_Kern
1983 - 2012 Ranger & B-Series
21
08-04-2008 07:31 PM
