Turbo wont spool. Only goes 30mph
I have a 1996 f250 psd and it was running good all day then i went to leave work and the turbo would not spool and it wont go over 30mph. I pulled over and turned it off and turned it back on then it was fine. Got home went to leave and did it again.. It has a new fuel filter, oil filter, oil, air filter cleaned. Please help
If you are right that it's EEC-IV, then yes, pulling codes will still tell you something. That system stores codes too. You just read them a little different from OBDII, and you need a different decoder list.
The other (minor) thing is that there's not realy any such thing as OBD1. Ford called their Electronic Engine Controls EEC-__, with increasing numbers as the generations went on. EEC-V coincides with the government-mandated change to a common platform, which was called OBDII, but the Ford EEC-IV (that preceded OBDII didn't really have any other name.
If you are buying a code reader, any OBDII will work for any make. But if you're looking for an "OBD1" reader you need to get a reader that works with Ford's EEC-IV, a Chevy "OBD1" reader won't necessarily work.
But back to the point, either system gives helpful codes. And although a code reader can make it easier to read EEC-IV codes, all you really need is a way to jump the Self Test In wire (in the EEC test plug near the driver's side hood hinge) to ground. Then when you turn the key on the check engine light will flash the codes.
on
bummer.time to ask over here:
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
they might know common issues right off to check and test first.
Blueoval_boy_64
11-26-2005 02:45 PM
