Getting a M500 as a first truck....
I'm 16, and in the process of buying a 61-66 Mercury M500. Its a 15,000 GVWR which I would assume that means its a M500. It has a pto driven wooden dump bed. Has a 4 on the floor. Labelled 1,2,3,4 I would assume first is bull low. 6.20:1 axle ratio. Not sure the engine, me and my dad both agree its most likely an I6 due to the high gearing, and the fact that the truck is so striped for options it only has a speedometer and an hour gauge. No idiot lights or anything.The floor is rotted out at the front, under the pedals. The gas pedal is missing, the seat is missing foam, the roof is bent in. The truck has not run in 10+ years, but ran when parked. So I am confident it will start now. The truck has 84000 miles on it. And the hour gauge reads 6000+. Not sure if that is a lot of hours and miles. I'm trying to get a job to pay for it. The seller wants $800, Ill try to get it for $700. I am wondering if they sell replacement floors for the cab, they should, it is just a half ton cab. I have to safety it once a year because it is over 3/4 ton. This is my first post on this forum, I am sorry in advance if I **** something up.
FourthGen Ford Guy Welcome to and the Slicks Forum.
You have me sitting he in North Carolina wondering what the heck a 16 year old wants with a huge tooth rattler like what you described. Are you looking to get into some hauling?
A couple of things you say 61-66 it can only be one of those years. The odometer starts over at 0 at 100,000.1 so your 84,000 likely has at least a 1,2 or more in front of it.
An old truck sitting for 10 years in Canada cold winters could very likely have a cracked block by now. You would be very lucky if it started and ran.
Asking and getting are two very different things, a couple-three hundred buck is about all that ol boy is worth. IMHO
GULUK!
John
GULUK!
John
Wonderful to see the younger guys take an interest in old iron. You mentioned it needing tires, but I'd first suggest you school yourself on those dually wheels. If it's an M-500 it could have either the big 5 lug x 8" pattern or 6 lug x 8.75" pattern. Either of them will likely have outer rims that are today called widow makers, trade name is Firestone RH-5°. Do yourself a Google search of those terms and read up on them. Not many shops will touch them anymore.
Most 61-66 era trucks had hubs designed for a "stud piloted" mounting. Could also be called a "ball seat" or "Budd" mounting. Some 63/64s, however, had what is called a "hub piloted" mounting. If you have widow makers, replacement options exist for either the 5 x 8" or 6 x 8.75" patterns. But no replacements exist today for a hub piloted mounting with these patterns. It is, however, possible to convert a truck from hub piloted to stud piloted. Stu
Truck could have come with a round speedometer instrument cluster that included fuel and temp gauges and idiot lights for the oil and amp gauges. Oil and Amp gauges were optional and flanked the round speedo. Or there could be a vacuum gauge and tachometer with a round speedo that had 4 additional gauges (fuel/temp/oil/amp) surrounding it.
You have a lot to learn...as this is the oldest lie in the old car hobby!
Do NOT believe the miles shown on the odometer, as it reads to 99999.9 then returns to ZERO! So it probably has 184,000, 284,000 or who the hell knows how many miles.
IMO, a truck in this condition, isn't worth more than 100 Loonies!
I-6 = 1961/64: Intake/exhaust manifolds located on the left (drivers) side. 1965/68: Intake/exhaust manifolds located on the right (passenger) side.
V8 = Depending on the year/series, it could have a 292 (1961/64); or a 330/361/391 FT engine if 1964/68.
1946/68 Mercury trucks were assembled and only sold new in Canada. Were not available in the US
IMO, you are biting off way more than you can chew. PASS on this old roiling pile of miseries, all the parts are OBSOLETE, so it will soon become a money pit!
Buying parts in the US will cost more because of Canadian shipping charges and VAT
What is the exact year? 1961/64 will have different engines than 1965/68. Transmissions could be different after 1964.
I'm familiar with the 1939 GM cars as I once owned a Cadillac 75 7 passenger sedan (formerly owned by MGM studios) and a La Salle w/a factory sunroof.
IMO, the front ends of these cars (excepting the La Salle) look rather sad. 1940 was a improvement, 1941 was even better.
I also owned a 1941 Cadillac 60 Special and a 1941 Buick Century Coupe with factory installed dual carbs.
All the brake parts (and sometimes the drums) are available from NAPA
I can probably find all the genuine Ford parts NOS, except the drums...which have been obsolete for over 30 years and are very hard to find.
I need to know the year, because there are different sizes of brake shoes, wheel cylinders.
"Typical" pic for 1964/72:
