So, I have a 1970 f100 stock 4 speed with a 351w bolted on to it and when I take off and I don't give it enough gas vs letting off clutch, the shifter literally almost slaps me right on my leg, and the passenger, I looked under there and everything. Looks good, when it does this it doesn't come out of gear or anything it's just annoying and plus I really don't want to tear anything up, any ideas what this could be?
Look and feel for broken or loose engine/trans mount.
You may need a jack and block of wood simulate the application or removal of engine torgue.
2X Hio. If the shifter does this still straight up but moving side to side look for a broken tranny mount. If the shifter is twisting back and forth clockwise and counter-clockwise look for one or both engine mounts to be broken. Note, "at rest" a mount may look OK. The two halves might have sat back down on each other correctly.
Shorty, you have a dangerous situation. Last year a fellow came in with a picture of an engine into the radiator. You should immediately replace all three mounts. One at a time. They are cheap.
There is a Toothless Jake way of checking for a mad motor mount: nose it into the biggest tree you can find and gently let the clutch in. Let wifey watch to see if the motor rolls up.
Pulling up the e-brake and loading also works.
Do not let wifey work the clutch. Otherwise, flattened tree, crushed grill.
Yea it stays straight up and down, just goes side to side hit me up side the head while reaching for something today
