New carb fade to stall at 750 rpm
Running a new Edelbrock 4-v intake and Eddy 4-V carb with electric choke.
I can adjust the idle to 1k rpm and it will say there for hours....
screw down the idle to 750, and the smoothness slowly goes away and will stall after about 10 minutes if left to just idle.
Vac leak (only noticeable at 750)?
Tried the needles, turn in till stumble and back out too.
Ron may be dyslexic. It is probably a 1406, which is the economy-tuned 600 CFM version.
It sounds like it is running very lean. I would do as was suggested - adjust the idle mix, keeping the screws in sync, until you get the best idle. However, if it is lean like I suspect you'll have to lower the idle speed with the stop screw as you adjust. Once you have best idle, regardless of how far out the screws are then set the idle speed to your liking.
But, if you can't get it to idle well with the screws all the way out you do have a vacuum leak. Possibly a hose left off? Or the carb's base gasket is bad - you did use the little plate Edelbrock sent with 2 gaskets - right?
I bought one recently and it did not come with what your describing but maybe it something jegs doesnt send out with it. make sure the back plug for auto trans kickdown is either all the way in or plug right I had to put rtv
one time i had a PCV valve go bad and had a huge air leak through there. I would just go ahead and check all the caps and hoses for leaks. Its kinda nasty but by taking them off and sucking on them like a straw to see if it holds pressure by having your thumb at the other end works well and is easy just brush your teeth after lol
Originally Posted by Gary Lewis
The carb comes with one gasket, but the Eddy Performer intakes I've seen came with two gaskets and a extra plate that goes between them. That's because the mounting flange on the intake is quite narrow and they wanted to spread the load. But, maybe yours doesn't need that?
http://www.summitracing.com/parts/edl-2732
I had to use one of these on my own truck. If you need this plate and do not have it, your engine will have a massive vacuum leak and won't ever run right.
Since you are running an Edelbrock carburetor on an Edelbrock intake, you may not need the adapter plate?
I think we're on to something here. Just checked and the carb is tight to the intake, but if I spray starter fluid on the rear of the carb/intake, it stumbles... pour it on and will stall.
I don't have the 2-gasket/plate set up, Didn't come with one.
Maybe Eddy will send the kit out as a freebie, since I fought the intake and carb about 5 months ago?
OK so I got the insulator gasket, but during install I tilted the carb and gas was flowing out the valve on top the front-left, is this OK? or is something messed up.
To get it to run smooth, the needles are so for out, there is no spring tension.
Turn them in some it goes down to 18" and stumbles.
But leaving it needles out (where smooth) I can not back down the idle adjustment.
With the idle screw out so it is not touching the stop, the revs are at 1200 rpm.
puzzling
puzzling
Ron - Remind me what carb? (You need that in your sig.) I don't think the gas thing is a problem, but I'm trying to remember where it is coming from.
The idle screws being that far out say you still have a vacuum leak and you have to compensate by giving it all the gas the idle circuit can provide. So, you need to find the vacuum leak. Do you have a gasket above an below the new spacer? Did you place them on the intake and carb and ensure they won't have leaks?
Mutilator712
16
10-16-2016 08:46 PM
lud04X
07-09-2007 05:21 AM
1965Blue
01-18-2006 03:26 PM
