Ignition problems again. Please help!
Old Apr 5, 2015 | 08:54 PM
Franklin2's Avatar
Franklin2
Originally Posted by oneofakind97
It seems to run better with the choke on and as it pulls off, the miss comes back.
The above is trying to tell you something. I am not sure exactly what; a vacuum leak? The idle mixture screws need a little tweaking?
Old Apr 6, 2015 | 10:24 AM
LARIAT 85's Avatar
LARIAT 85
It's starts up and idles fine and then the idle gradually drops and I assume that is the spark dying off? Then it misses throughout the entire rpm range and runs really really rich. Blows a lot of black smoke out of the tailpipe.
IAll the plugs had carbon all over them. That was about it. I figure that's just from the way it idles. I haven't even gotten to drive it much. It's always just idling in my driveway.
Edit: the carb is a holley truck avenger 670. I put it on the truck right out of the box and didn't mess with the jets any. The only thing I did was put a different accelerator pump cam in it.
That carburetor is WAY too big. That is probably why it is running "really really rich" and "blows a lot of black smoke out of the tailpipe."
A 5.0/302 doesn't need anything bigger than a 600 cfm carburetor; and even that is pushing it.
Old Apr 6, 2015 | 11:58 AM
oneofakind97's Avatar
oneofakind97
When it's firing on all cylinders it doesn't run rich at all. I only have these symptoms while I have intermittent spark. I would assume it's caused by the fuel being only partially burned during combustion.
Old Apr 6, 2015 | 09:00 PM
trevisM's Avatar
trevisM
My uneducated guess is (can't see or hear over the net) is it runs rich until a plug or two gets fouled and then begins to miss. Above post that a new dizzy would result in another bad dizzy is based on a piece of advice given to me about fifty years ago, "boy most distributor problems are located in the carburetor and most carburetor problems are in the distributor."
Try running it with 450 cfm, just for grins.
NCHD
50
Oct 2, 2022 04:18 AM
'84 F150
Dec 5, 2011 11:09 AM
irishguyincc
1983 - 2012 Ranger & B-Series
38
May 2, 2006 08:02 PM
grey77
1978 - 1996 Big Bronco
Apr 6, 2005 01:24 PM
ford351c
Electrical Systems/Wiring
Jun 22, 2004 01:33 PM
