351M to 460 78 Bronco ?s
After spinning the front main bearing I decided to swap out the 351M to one of my two 460s. I have a 74 Lincoln Continental (internally balanced) and a 88 F350 460 EFI. I know I want the EFI but am wondering if the EFI from the 88 would fit on the 74?
Also would I be best of to run the HP built C6 or the newer automatic tranny from the F350?
Also what all garbage emissions stuff can I remove from the 88 460 and it still run decent with no issues? I live in Colorado and do my emissions every 5 years.
Any help is greatly appreciated.
460 efi heads are different than non efi heads. The intakes won't interchange.
You can put the efi heads and intake on the 74 engine though.
If you're running efi, I would run the overdrive trans. If the efi 460 had a c6 then it doesn't matter.
You don't need any emissions crap. Get rid of it all.
mike83f250
02-19-2010 10:53 AM
jwmustangman
01-31-2006 08:42 PM
