Cab squareness
Old Apr 2, 2015 | 07:38 PM
my1954fordf100's Avatar
my1954fordf100
Cab squareness
I have my cab mounted and the passenger door fits perfect but i'm having driver do fitment issues.
i searched the threads for cab mounting, didn't find anything
i have the cab front mounts tight and the rear mounts are tight..... I have it measured left right and frame height to bottom of back window.
Is there a proper way to make sure i have my cab square or give me the link that is hiding from me?
Thanks
Old Apr 2, 2015 | 07:49 PM
bobj49f2's Avatar
bobj49f2
I had experience with adjusting the cab on my '49 F-2. The cab I used was from a F-7 firetruck with 3000 actual miles so it was about as close to factory original as you could get but the doors fit like crap. It's been about 20 years since I mounted the cab but as I remember the top back corners on but doors hit while there was a wider gap in the front corners. I ended up using a port-a-power to jack the door openings square so I had a nice uniform gap all of the way around the doors.
I don't know if this helped with your situation but I just wanted to let you know these cabs weren't perfect from the factory and you can do a little adjustment if needed.
Old Apr 3, 2015 | 08:37 AM
56panelford's Avatar
56panelford
Has your cab had any work done to it like floor patches or rockers been replaced?
Old Apr 3, 2015 | 09:52 AM
52 Merc's Avatar
52 Merc
Thanks
You said you have issues, but you didn't say what they are? Hard to diagnose/help if you don't know what the problem is. A little more info would be handy.
Old Apr 3, 2015 | 08:59 PM
my1954fordf100
rear floor, rear cab corners and rockers have been replaced.
luckily with a few hours today and a fresh set of eyes i now have the door fitting. i guess i just needed to post something.... ;-)
Old Apr 3, 2015 | 09:01 PM
56panelford
I guess you just played with the hinges?
Old Apr 4, 2015 | 07:52 AM
pweng1's Avatar
pweng1
Hinge twist and sag is a big reason for improper door alignment. I notice while taking mine apart the screws and brackets have some play. I am having to set mine in position before bracing.
Old Apr 4, 2015 | 11:45 AM
jimcar-9's Avatar
jimcar-9
Make sure the front frame cab brackets are not saging.....
Old Apr 4, 2015 | 08:51 PM
my1954fordf100
Figured out that that rear cab was 1 inch to high, lowered the rear cab 1 inch.
adjusted the hinges a bit plus made 2 1/8 plates to put on the back side of the hinge to push the door out.
also a little hammer and dolly and flapper wheel.
got the bed adjusted and tomorrow i'll do some more fitting.
Old Apr 5, 2015 | 12:06 AM
jimcar-9's Avatar
jimcar-9
Are you sure it's the rear that is to hi? And not the front that is to low?
Old Apr 5, 2015 | 06:51 AM
my1954fordf100
Yes the rear of the cab was to high.
i am sure glad i live 25 mins from Dan Carpenter, i went and talked to him about it and looked at his trucks.
Old Apr 5, 2015 | 06:57 AM
jimcar-9's Avatar
jimcar-9
How did you lower the rear?
Old Apr 5, 2015 | 08:03 AM
56panelford
Good question.
Old Apr 5, 2015 | 08:11 AM
my1954fordf100
I have the adjustable cab mounts from mid fiftys.
Old Apr 5, 2015 | 08:12 AM
my1954fordf100
I originally set then the same length as my old solid ones.
