96 F-150 Manual to Automatic Trans Swap Help Needed
I have a 96 F-150 4WD Super Cab with 5.0 and manual trans. I would like to convert this truck to EAOD trans and have been looking to buy a complete running and driving donor truck. Is any 92-96 with 5.0 and EAOD a good candidate or, some better than others? Any other special considerations for the donor truck and other insight would be appreciated !
There is no EAOD transmission. In this vintage F150 it would have an E4OD or 4R70W. Since your truck is the first year with OBD-II powertrain computer system the only viable candidate will also be a 1996 F150 or Bronco. You would then use the donor transmission, computer and wiring harness for the transmission. Same for other hard components.
The most common combination in a 1996 F150 w/5.0L engine is the 4R70W transmission. Although there are a few on this forum that have verified they have the 5.0/E4OD engine & transmission. Broncos came with only the E4OD.
On the other side of the coin you could source an earlier model truck with the mechanical AOD that has no computer controlled operation. Those were used from ~1986 to 1993ish. This would require no computer swapping since your 1996 has a manual transmission.
That's what I plan to do and I even I do this right now with my auto trans still installed. I have a few codes for various things but I know what they are and just ignore them because they're all non-critical.
I have a HEGO code for the heater in the post cat O2 sensor, but it's been there for nearly 10 years..she still goes closed loop so I'm not worried. New sensor didn't take care of it, so I just let it go. Those little ELM327 bluetooth code readers and a smartphone are handy on the OBD-II trucks. My CEL bulb burned out years ago though, haha
rla2005, thank you and the others who have offered advice on this subject. Can I reuse my existing manual transfer case or, are the transfer cases used with automatic trans different? If I opt to go with an earlier trans that is not electronically controlled, what do you suggest in terms of steering column vintage that will connect to the 96 column wiring yet work properly with early trans?
The transfer case is the same for manual vs. auto. The column may be a different story. I am not sure if the 4R70W shares the same shift pattern as the earlier AOD steering column. If it is then you can use a 1992 to 1996 steering column from a vehicle with an AOD or 4R70W. If not then you are limited to the 1992 to 1993 columns. Also be aware the 1992 and 1993 columns do not have an airbag so something else to consider here.
emschris
10-28-2014 05:05 PM
capriceragtop
03-10-2013 03:44 PM
dizturbed
08-10-2010 10:32 AM
92_FlareSide
08-25-2005 12:25 AM
