Valve job advise
I needed hardened seats and bought a set via Advance online and was less than $200 a head, came rebuilt with hardened seats.....since my heads were nothing special was a lot cheaper than having them rebuilt. I have been running well over a year with zero issues. I did have to set up the springs as I am running a little performance cam but no biggie...they were pretty much bolt on for stock applications.
Hardened valve seats on the D2 head question
RJP
<hr class="post_separator"> Joe-JDC
Re: Hardened valve seats on the D2 head question
« Reply #7 on: April 16, 2015, 07:39:05 PM »
If you are lucky when the heads are cleaned, there will be a discoloration in a circular pattern around the exhaust seat area that has a blue/black tinge to it if the hardness has not been cut away. Looks like a piece of metal that has had a torch taken to it and then quenched in oil. You can visually notice the difference on a fresh/new head. Joe-JDC
« Reply #6 on: April 16, 2015, 11:32:43 AM »
Exactly which is why I had hardened inserts put in. They weren't expensive for the piece of mind as well as new guides which cost $85 for them. My rebuilt 360 to 390 including heads (original valves all good), block, all parts except my cam and lifters, including balance of the assembly at $295 cost me $2300. Out here in the Bay Area that isn't bad.
Okay any body come up with the real deal on 1975-76 360 heads??/ Do they have the hardened inserts rather than then induction harden
hardened seat insert
area under the valves ( Seats ) I'm trying to find a set of heads for my Fe ford engine that will handle unleaded fuel with out the worry of pounding out the valve seats I was under the impression that the 360 FE from 75 up had a hardened valve seat ( Inserted into the cylinder head not just induction hardened area around the valve seat area )So what I'm asking is do these heads have the hardened valve seat machined into the valve seat area
Yes, that is correct. If you click on the thread titles in post #21, you can go to the thread and read more on the info there. You can purchase inserts and install them but there is a chance of breaking into the water jacket on install
Thanks 62, I found out motor is a dealer 390 long block, heads have one side guides installed the other side not, head gasket installed backwards from them drivers side , a couple of valve spring shims not there where as 14 others have .60 washer under spring . Rear pass cyl scored heavy grooves
Martin Torres
09-23-2016 12:08 AM
supercabfreak
36
11-26-2011 07:07 PM
YoungMT Hick
16
03-18-2007 12:05 PM
JermKline
15
05-25-2005 07:01 PM
Charles
07-27-1999 09:39 AM
