Today is the day........
Received 3,946 Likes
on
I have 5 bucks for you too Rodney. It will be in the form of a commission check for all the crap you made ME buy though.
I didn't realize there were down payment requirements for the longer term loans, but still, you can't argue with free money. I was able to do $0 down and 0% for 60 months. Those numbers worked very nicely with my budget, and considering that prior to that, I didn't even think I could afford a tractor and implements, I'm glad they were advertising their deals during the morning news.
on
Started some repairs to my swamp today. This pipe has been messed up since the neighbors trash guy tossed his tote in the ditch during a bad storm a few years back. It sat about 2" above grade after the water jammed the can against it and lifted it out of the ground. Yesterday I found it only went to the edge of his driveway and then went into concrete pipe, so today I dug it up, pulled it out, lowered it and reburied. What a mess. Next step is to move my gutter and sump pump drain to dump directly into the plastic pipe, but this was a huge step. Next huge step will be when I run 200' of pipe and get rid of the stupid ditch completely.
After the pic I went to my parents to grab a big flat rock to put on top of it. Dad has a ton after filling his pond in. Loaded rock, had a beer, went to leave and got the 6.7 Christmas tree when I released the e brake! Low oil pressure, coolant overtemp, mileage disappeared, wrench light, every idot light on the dash lit up. Crawled under the dash and figured the lock out on the e brake connector, unplugged and reinstalled. Fixed. Glad I got that tip from here! Will have to release and tighten pins and move connector sometime.
I'm going to be stuck with taking Deere's 0% for 12 months. Oh well, I don't want to carry the note anyway, just better than dumping 8k all at once.
Been fairly pleasant here the past few days, upper 40s or low 50s. Been mid 20s at night though. That spot is so damn soft all the time. Where the sump pump dumps a boot will sink 8" right now. It has permeated the whole area to the point i need to be very careful or it will suck the tractor in. Trying to keep the (future) zero turn out of the mud, and keep myself from having to wheedwhack the entire ditch all the time.
