Today is the day........
  #9991
Old 07-04-2017, 08:57 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
Originally Posted by elee3 View Post
Are you guys superstitious or something?
Only about that number, walking under ladders, stepping on cracks, etc...JK
  #9992
Old 07-04-2017, 09:26 PM
elee3's Avatar
elee3
elee3 is offline
elee3 is a splendid one to beholdelee3 is a splendid one to beholdelee3 is a splendid one to beholdelee3 is a splendid one to beholdelee3 is a splendid one to beholdelee3 is a splendid one to behold
Yep, me too. When I played baseball, I'd never step on the chalk lines. I won't walk under a ladder and don't like to stop a fuel pump on any 13. Bananas aren't allowed on my boat. There are many others that I just can't think of right now.
  #9993
Old 07-04-2017, 09:38 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
I'm not at all and was just playing as I know folks love to worry about these things...LOL.
  #9994
Old 07-04-2017, 11:12 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.
Originally Posted by Chad149 View Post
Drain plugs are the exception, not the rule...
What is the best practice for draining then? Suck it out or pull the cover?
  #9995
Old 07-04-2017, 11:22 PM
Chad149's Avatar
Chad149
Chad149 is offline
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
I pull the cover. Only way to drain it completely and provides an opportunity to look it over good since its not something you have to service very often.
  #9996
Old 07-04-2017, 11:25 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is online now
ExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputation
If you are set up for max replies per page, it's only page 250.
I am assuming you don't need the power supply for those LED lights, they just run off the 12V system?
  #9997
Old 07-05-2017, 06:08 AM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Yep, I just tied them into an existing 12v switch Eric. No power supply needed...
  #9998
Old 07-05-2017, 06:40 AM
PlayersZ28's Avatar
PlayersZ28
PlayersZ28 is offline
PlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant futurePlayersZ28 has a brilliant future
Originally Posted by Karl4Cat View Post
After seeing Tony's install, I went with his method as opposed to what XLR is doing on their current builds. They have them firing straight down but you loose light that way. His (and now, mine) are along the outside lip facing in towards the cabinets so they hit the dark wood and create a glow. It's not as spacey in person. My cam had a hard time figuring how to focus on the various light sources. Very cool though and matches what was already up above. I'll have to take some night pics later when the sun drops...
So the strip is in a vertical position? You stuck it to the inside of the counter edge buildup? Was going to ask how well it followed the curve but if it's mounted that way then it didn't have to curve.
  #9999
Old 07-05-2017, 06:49 AM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Exactly. It's on the outside of the groove facing in.
  #10000
Old 07-05-2017, 07:47 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
Originally Posted by fordmantpw View Post
Happy 4th everyone!
We just took a trip to the St. Francois Mountains in SE MO. I've lived in MO my entire life, but hadn't been to this part of the state before. It's beautiful, and probably the most scenic part of the state. It's also home to the highest part of the state at 1790' above sea level. The negative is the roads. They're horrible! Curvy, winding, hilly, and patchy pavement that makes for a rough and grueling trip. I was beat by the time I got finished with the 3+ hours of driving that stuff. The good side is that the truck did great. Couldn't have asked for more. The slow trip makes for good fuel economy too...12.5 MPG pulling 10k lbs of fifth wheel.
That's a lead in to a question I've got for all you fiver towing experts. On many of the sharper turns, about halfway through the turn, it will feel like something slips and then catches. Almost like you've got a load of water and then it suddenly shifts and sloshes against the other side. I've never felt this sensation before, but I've never had such a long trip on these hilly, curvy roads either. Any ideas what it could be? I did air the rear tires down on my truck to about 65 PSI on this trip down from the usual 80 PSI, but with only 1200-1500 lbs of pin weight, I don't think that's the issue. I always ran 60 PSI in my F250 and never experienced it. Any ideas what this could be?
Hey, can you grab the hitch plate and move it up and down laterally? Some hitches don't have much articulation side to side, as if the truck is leaning left 4 and trailer is off camber 4 right. On mountain switchback roads you may have hit the camber limit a few times which would put the twisting stress on the base and pucks and they do have some slop in them. It's hard to describe....older hitches had equal fore and aft articulation and port/starboard so there was full range of motion on the hitch head. Some newer ones just have rubber bushings and the side tilting is very limited.
  #10001
Old 07-05-2017, 07:57 AM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Welcome back Joel!!!
  #10002
Old 07-05-2017, 08:26 AM
Sailor_Roy's Avatar
Sailor_Roy
Sailor_Roy is offline
Sailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputation
Were Bananas allowed on Subs.......
  #10003
Old 07-05-2017, 08:34 AM
fordmantpw's Avatar
fordmantpw
fordmantpw is offline
fordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to beholdfordmantpw is a splendid one to behold
Hmmm, that's a good point and I see what you are saying. I do have the rubber bushings that the head sits on with my B&W. I know I have good front to back movement, but I will check the side to side. I don't remember there being much. I do know it's much more difficult to get the head down all the way on this hitch vs. my last B&W.
Another piece I forgot to mention. I've got the Reese Sidewinder/Revolution on my fifth wheel, so it basically locks in place in the hitch so all the rotation is at the trailer and not the hitch. I'm going to double-check that for fit as well.
  #10004
Old 07-05-2017, 09:53 AM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
So, just got off the phone with Ferrara Spring. They are going to drill my lower overloads and install the StableLoads. They said the easiest way to do it was to pull the spring pack and do it on a press. Worst case scenario, 3 hours at $95 per. Yikes. Here's to hoping it goes quick...
  #10005
Old 07-05-2017, 11:26 AM
golfmedik's Avatar
golfmedik
I didn't think the B&W was compatible with the Reese hitch due to using a capture plate?
Quick Reply: Today is the day........
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
