Today is the day........
  #16201
Old 09-20-2018, 06:35 AM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is online now
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
That would be my second free option Chris. Being a painter by trade, I tend to have a few leftovers lying around though.
  #16202
Old 09-20-2018, 06:38 AM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
KubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to all
Lol i fogured so,
i just had to throw a little redneck in this am
  #16203
Old 09-20-2018, 09:38 AM
my_crib_too's Avatar
my_crib_too
my_crib_too is online now
my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.
Originally Posted by Ferguson65 View Post
Here comes Scott with his .04 whether you want it or not!
Why must the boards be removable Rodney? Sure that mesh kit is removable but certainly not tool free. And sure not cheap. Bri Mar does kind of screw you on the stake pockets. You either widen the bed or narrow it as the pockets are in the top rails. If you are considering buying, I'd recommend the side board gusset kit I have. It's $225 which is expensive for what it is. A 2x12 on top of the existing sides is perfect IMO. Good bit of extra depth, but still easy to throw stuff over the sides. I have never had a reason to want to remove mine. You could use hitch pins to secure the boards to the gussets and pull 3 pins and clips to remove boards if you really felt a need.
Just my .04. .02 you wanted and .02 you didn't. Lol.
Originally Posted by Karl4Cat View Post
The sides must absolutely be removable for loading firewood. You can't load neatly and stack from the rear and with the side extensions in place, it would be impossible from the front and sides. If I wanted a 4' side dump, I would have bought one. I bought a short side model so I could have removable sides. That said, the side extensions must also be taller than your 2x12's for trash dump duty. So, your system just wouldn't work for me on a few levels...
Is this the exchange in question?
bruce...
  #16204
KubotaOrange76
you guys have any fancy methods or tools for bleeding brakes solo?
Just changed the brake hoses on my 89, and i didnt quite get all the air out with my hand powered vacuum pump.
I figured there is probably something better out there, been using vacuum pump method for years now but always wind up having to recruit someone's assistance. Tired of fighting it.
  #16205
Old 09-20-2018, 09:58 AM
Karl4Cat's Avatar
Karl4Cat
WAY too much time on your hands Bruce. Go chase the wife around! LOL
  #16206
Old 09-20-2018, 10:03 AM
Dim Sum's Avatar
Dim Sum
Dim Sum is offline
Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.Dim Sum has a spectacular reputation.
I swear by mine vs swearing at the vacumm methods:
https://www.motiveproducts.com/
  #16207
Old 09-20-2018, 10:40 AM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
That's what I have. It works well most of the time. It didn't bleed the Jeeps brakes worth a darn. The Fiat it worked like a charm.
  #16208
Old 09-20-2018, 10:53 AM
KubotaOrange76
Does this basically clamp onto the master cylinder, and pressurize on the top end ? Sounds like pretty fool proof method. Does the reservoir hold brake fluid as well so you dont have to keep removing the cap to add fluid?
  #16209
Old 09-20-2018, 11:51 AM
SavageNFS's Avatar
SavageNFS
yes. Mine, you fill the master cylinder, fill the vacuum, and screw on a cap with a line to the vacuum reservoir. It constantly feeds the master cylinder fluid from the reservoir as you put build up pressure in the vacuum. This video is a gem. The car is a pile, but the technique is spot on. I just use 20psi is all. Seems to work a little better.
  #16210
Old 09-20-2018, 02:35 PM
Chad149's Avatar
Chad149
Chad149 is offline
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
I've never had a lot of success vacuum bleeding air out of the brake system. Works best for freashing up the fluid. Either get a pressure bleeder, or get the wife to pump the brake pedal and bleed the old fashion way.
  #16211
Old 09-20-2018, 02:57 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.
I use the SpeediBleeder. It works great. The ONLY downside is that it hooks up to the tire's valve stem to pressurize the tank. I think the last time I used it I used a bicycle tire instead of the vehicle's tire. That's a good work around if you don't have a compressor at home.
Be sure you clean the tank and hose each time it's used. A generous squirt of brake parts cleaner in the tank, swish it around, pressurize it and let it come out the hose. Takes just a couple minutes.
EDIT: The SpeediBleeder even worked on my ATV's brakes.
  #16212
Old 09-20-2018, 03:08 PM
SavageNFS's Avatar
SavageNFS
That is a NICE bleeder Jim!
  #16213
Old 09-20-2018, 03:36 PM
KubotaOrange76
https://www.youtube.com/watch?v=miv3jjN95ok
thank you! now i just got to bring myself to spend the $, got it in the amazon cart
Me either, it usually gets me close and gets the fluid good and flushed. Then i recruit a friend or wife to pump pump hold to get the last of the air out. Problem is now with a 1 year old and 4 yr old the wife usually isnt available lol.
  #16214
Old 09-21-2018, 01:14 AM
Sailor_Roy's Avatar
Sailor_Roy
Sailor_Roy is offline
Sailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputation
BINGO.......
Sorry Rodney....... The devil made me do it..........
  #16215
Old 09-21-2018, 09:09 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Paw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to behold
Protective coating technician in military terms!!
Quick Reply: Today is the day........
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
