Today is the day........
#1546
Had a bunch of reading to do to catch up on this thread.
My trailer was winterized when I bought it this summer but I checked it anyway and added some pink to the traps and blk tank. My last trailer I just used to blow the lines out and then do the traps. This one was done by pumping pink thru the lines. I looked in at the pump and there's a hose connected that you stick into a pink bottle.
Will the blk tank flush line hold water or does it drain out into the tank?
For the line blow I just use a standard trigger blow nozzle and wrap it with elec tape until it seals into the city water connection when I hold it there. Seemed to work the past 5 years.
#1547
#1548
The Camco one Rodney posted above is the one I have. All great except the quick connects I use don't fit. Since I was going to Ace anyway I picked up the part to make my black tank AF pump. Had the pump, just needed a few little fittings and stuff.
The wiring was just a quick make it work, don't judge. Dump trailer had the closest battery. My outside shower is on the L/F of the trailer so that was out.
#1549
#1550
Yep, should be easier the second time around! We've started to dive into making plans for our trip. Wife still freaking out as she's never been in a car more then about 5.5 hours.
You're a bit closer to leaving..................Got a plan or just going to see where the wind takes you once you get there?
#1551
#1552
Received 5,160 Likes
on
#1556
on
#1557
#1558
#1559
#1560
Still have some tasks to do before then. Would like to add 2 6v batteries, a better battery usage monitor than the 4 leds and I need to pick up a small genny.
