Check engine light is on...not blinking. All fluid levels are good. Mileage is 10,700. No code displayed in engineering mode. Truck seems to be running fine.
Any suggestions?
Stop by the dealer? If for some reason you do not want to do that, you could swing by autozone and have them put the code reader on it. Not sure that everything shows up on the LCD or not.
Are you gettting a "Oil change required" notice on start up? That will set the CEL and it stays on even after you clear the notice. Your milage looks about right for that.....
Never had a CEL for this. And yes, I have had the oil change required message.
Go by the AutoZone and let 'em try to read your codes. It's free. My son's gas cap was loose and after tightening it took 2-3 days before the warning went away.
Back from dealership. Problem fixed...."Performed TSB 13-10-11". Whatever the hell that is. Anyway no more check engine light and no money out of pocket
[QUOTE=Thom12;14127725]Are you gettting a "Oil change required" notice on start up? That will set the CEL and it stays on even after you clear the notice. Your milage looks about right for that.....[/QUOTE
-I recently had the exact same happen. Had driven 5000 miles and got the (expected) "oil chg required" light. Dealership performed the oil chg and now I have a solid 'check engine light" (CEL) lit. Fuel cap tight. Did TSB 13-10-11 fix this?
