Truck overheated, need suggestions
I was driving down to my parents place the other day and i noticed my temp gauge climbing, thought nothing of it as it was only a bit above the middle. Made it there and it was at the top of the normal range, not in the red tho. Let the truck cool down for a few hours while i went and bought a new reservoir cap thinking that was the issue. Coolant was still full when i replaced the cap and the same thing happened to me on the way home. got a little warm and started creeping up to the top of the normal range. I'm thinking at this point it's either the t-stat or water pump, truck has 204k on it and as far as i know both of those are original parts. Any body think i should lean towards one part or the other?
If the pump isn't leaking, grab the fan blades (preferably with the engine off 😀 and see if there's any play in the shaft. If not, don't worry about the pump for now. Swap out the thermostat. Sounds like it's your main issue anyhow. Whether it's not opening fully or just sticking, it seems to be the problem. Or the easiest one to begin with.
Wouldn't hurt to install a real temp gauge either, the stock gauge is really just an idiot light in the form of a needle, and I have seen one factory gauge sending unit go bad and kept reading hot on a F-150 gasser. The owner replaced the t stat, fan clutch and radiator before he realized the gauge was lying. Even a hand held temp gun would've cleared that up. If it gets hot on the highway look for clogged radiator (inside and out) or bad t stat, if it gets hot around town add the fan clutch to that list. But first make sure your idiot gauge isn't lying.
Cooling issues never seem to be the simple fix. There is just so much that is dependent upon such as scheduled maintenance that affects the systems.
If it's not cooling, there are three area's of concern.
Water not moving - Pump, Thermostat (more often than not, the T-Stat fails OPEN not closed)
Air Not Cooling - Fan Clutch - Blocked Radiator
Weak or not maintained Coolant
Unfortunately, maintenance, or lack thereof, will affect each component.
So, don't be surprised if you have to dig deeper to fix this issue.
I have pulled pumps where the impellers were broken off the end of the shaft where the belt was literally the only thing holding the shaft in place. Removing the tension on the belt caused the fan to fall forward into the shroud.
I've seen radiator cores clogged from mineral buildup which required replacing.
The possibilities are limitless.
Just don't allow yourself to be surprised if you need to go deeper.
Once you get it figured out, I would however suggest you do a complete flush of the system and inspect those three hoses closely. Better to change them now than later and have to shell out the $60 or $80 bucks for Anti-Freeze again.
