Fuel Filler Neck 1970
Old 07-24-2003, 09:59 PM
#1_Redneck88's Avatar
#1_Redneck88
#1_Redneck88 is offline
Cool Fuel Filler Neck 1970
hey im back for another question does anyone know were i could find a fuel fillerneck for a 1970 f100 dennis carpenter doesnt have it nor does any of the other old ford truck catalogs i have will rubber hose do it or does it have to be a certain rubber or not .
Upper Case edited by FTE Administration
Old 07-24-2003, 10:11 PM
MuchToMyDelight's Avatar
MuchToMyDelight
MuchToMyDelight is offline
Whoa, buddy, ease up on the caps!! I would think that any rubber hose would suffice, as fuel line is rubber (i.e. 3/8 in stuff from the frame to the filter) but good luck finding one big enough. Have you tried the scrap yards? one for a 68-72 will fit and a 67 should too. The 67 has several little oddities to it as you will soon discover if you spend any time on this board.
Welcome to FTE!!
Old 07-25-2003, 01:28 AM
rebocardo's Avatar
rebocardo
rebocardo is offline
What are you looking to buy, the metal part of the neck or the rubber hose. Fuel line is a special type of rubber hose, regular rubber hose like vacuum line will quickly be eaten away and swollen if used with gas.
2 1/4 is the standard size for filler necks and you can get a lot of wierd sized stuff from NAPA.
Old 07-25-2003, 08:30 AM
rmt's Avatar
rmt
rmt is offline
If you're looking for the rubber piece from the in cab tank to the metal piece that goes through to outside, I just bought one from Dennis Carpenter. Look on p. 23 of the newest catalog under gas tank related parts. There's other parts you might be after there too.
Old 07-25-2003, 06:05 PM
stroker393's Avatar
stroker393
stroker393 is offline
Give Carolina Classics in Durham, NC a call. They fixed me up with the hose from the tank to the spout and the rubber oring around the spout which seals the outside. they also have a cool catalog.
(800) 598-4211
Old 10-02-2012, 10:17 AM
hdbagger's Avatar
hdbagger
hdbagger is offline
my buddy got one for my extra tank with a metal sleeve i believe from lmc. i am not promoting any company. i am new and looking for sites also and bone yards
Old 10-03-2012, 03:05 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by #1_Redneck88
Does anyone know were I could find a fuel filler neck for a 1970 F100? Dennis Carpenter doesn't have it nor does any of the other old ford truck catalogs I have.
Will rubber hose do it or does it have to be a certain rubber or not.
What are you asking for, the steel filler tube or the neoprene rubber filler hose?
These are two individual parts, they do come as one. The rubber hose clamps to the filler tube and to the outlet on the fuel tank.
C1TB-9047-A (replaced 78-9047) .. In-Cab Fuel Tank Neoprene Rubber Filler Hose / Reproduced by Carpenter as part number: 78-9047
Applications: 1970/72 F100/750 // 1937/48 Ford Passenger Cars // 1948/52 F1/F3 // 1953/56 F100/950 // 1957/69 F100/800.
C7TZ-9034-F .. In-Cab Fuel Tank Steel Filler Tube / Obsolete
Applications: 1967/72 F100/750.
PARTS INTERNATIONAL in Farmers Branch TX has 1 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 7 = 800-543-4959.
Originally Posted by Stroker 393
...and the rubber oring around the spout.
No such thing as an oring, you're speaking of the rubber grommet that fits onto the in-cab fuel tank's filler tube on the outside of the truck.
DOTZ-9080-B .. In-Cab Fuel Tank Filler Tube Grommet / 1970/72 F100/750 / Reproduced by Carpenter, listed on the same page in his catalog as the filler hose.
Old 10-03-2012, 11:55 PM
67-F100's Avatar
67-F100
67-F100 is offline
i got a brand new piece of rubber hose for it, its made for fuel. i have it on my truck. i bought a ft of it and it was pretty expensive.
$10+shipping
Old 10-04-2012, 07:22 AM
acreature's Avatar
acreature
acreature is offline
I just received parts from tank to cap (-cap)
Two Clamps $1.90
Fuel Neck Grommet $8.95
Fuel Filler Pipe $19.95
Gas Tank Connect Hose $6.95
All from LMC
Old 06-01-2019, 01:32 PM
mytoolman's Avatar
mytoolman
mytoolman is offline
Grommet clarification please
Mr Number Dummy...is the grommet for the filler neck tube for the auxiliary gas tank in the side of the bed the same part number as the grommet for the fill neck in the cab?---I need both for the repaint on Brutus the 1972 F250 Custom Sport...
Old 06-01-2019, 06:49 PM
mrpotatohead's Avatar
mrpotatohead
mrpotatohead is offline
Nope, I had a hell of a time finding one for my 69. Seems like I found an OEM one.
Word of warning to all, the hose clamps that Dennis Carpenter provides with their rubber filler neck hose are absolute crap. The Chinese wouldn't even make such a piece of doo doo.
Old 06-02-2019, 02:09 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
Here ya go: 70/72 F100/250....2.15" I.D.- 3.36" O.D.- 1.3" thick...."use with 25 gallon auxiliary under cab fuel tank".......D0TZ9080A.
Old 06-02-2019, 04:02 AM
NumberDummy
Originally Posted by GaryKip
70/72 F100/250 Styleside ....2.15" I.D.- 3.36" O.D.- 1.30" thick / Fuel Tank Filler Neck Grommet - Use with 25 gallon auxiliary under cab fuel tank.......D0TZ-9080-A
1970/72 F100/750 = D0TZ-9080-B .. Fuel Tank Filler Neck Grommet - Use with In-Cab Fuel Tank / 3.45" O.D. x 1.91" I.D. x .91" thick.
1970f100guy
04-23-2017 06:31 AM
DisneysPatB
01-31-2017 06:01 PM
Earnie Rosenow
06-01-2016 02:37 AM
Colby2014
09-22-2015 05:09 AM
systemofadowntox
02-17-2004 06:47 PM
Quick Reply: Fuel Filler Neck 1970
