1964 Power steering choices?
HI as spring nearly here in New Hampshire, time to play;has anyone used fat man fabrications steering pun as a way of adding power steering? or am I (with my 1964 F100 Y8 floor shift) going to have to use a ram assist? ANd how do those things work?
Thanks in advance
Thanks in advance
2WD or 4WD? Where in NH? Im on the seacoast....there are many posts about power steering upgrades in this forum. I have yet to see anyone post a start to finish upgrade for a 64 four wheel drive. I have some thoughts I am kicking around but wont get to that until end of summer, maybe end of fall. Let me know what you find out...
I'm working on this now. The 64 steering column is very difficult to find. I ended up buying one from some guy, and the shaft was bent. I'm now going to attempt to use a 67 column with the 64 box, connecting them with a Heidts' u-joint. I'll be taking pictures as I go.
Edit: Oh, I'm staying manual, so this probably doesn't apply. sorry.
1965/72 F100/250 2WD, 1967/72 F350: The steering shaft and flange connects to the input shaft of the steering gear w/a rag joint.
So, how in the world can you use a 1967 gear box w/a 1961/64 steering column since there's no separate input shaft on these trucks?
Light Doug
08-19-2018 08:47 AM
Smoke_Dog
01-13-2013 06:48 PM
mkoser
11-05-2009 06:18 AM
whayes75
08-25-2008 07:19 PM
