truck running bad after burnout
Man this truck is Killen me.!!!! 2002 harley f150 Just got it running good did one wot burnout around a rite hand corner , now running worse than ever I just put new Ford cops , new factory plugs , new iat sensor , fuel filter , rebuild rearend what's the sense if u can't beat it a little .It's miss in at idle now and continues up to 45 at least . No codes no cel what now fuel pump. Any suggestions would be appreciated
vac leak,one of the fuel pumps out, or exhaust leak before O2 sensor maybe.
<table border="1" cellspacing="0" cellpadding="3"> <tbody><tr> <td align="left" valign="top">P0171 - System to Lean (Bank 1)</td> <td align="left" valign="top">The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. Refer to Section 1 , Powertrain Control Software, Fuel Trim for more information.</td> <td align="left" valign="top">Air Measurement System
</td> <td align="left" valign="top"></td> <td align="left" valign="top"></td></tr></tbody></table>
- MAF sensor (contaminated, damaged, malfunctioning, etc.)
- Fuel pressure regulator (leaking, malfunctioning, etc.).
- Fuel filter plugged, dirty.
- Fuel pump (weak, check valve leaking, etc.).
- Leaking/contaminated fuel injectors.
- Low fuel pressure or running out of fuel.
- EVAP canister purge valve leaking (when canister is "clean").
- Fuel supply line restricted.
- Fuel rail pressure sensor (incorrect reading).
- Air leaks after the MAF.
- Vacuum leaks.
- PCV system (leak, valve stuck open, etc.)
- Improperly seated engine oil dipstick.
- Air induction turbulence due to incorrect air filter.
- Exhaust leaks before or near the HO2Ss (exhaust manifold gasket, mating gaskets, etc.).
- EGR valve tube/gasket leak
- EVR solenoid vacuum leak
- Damaged/malfunctioning secondary air injection system (mechanically stuck valve).
- MAF sensor (contaminated, damaged, corroded connector, etc.).
- Fuel pressure regulator (vacuum hose off, diaphragm leak, malfunctioning, etc.).
- Leaking fuel injectors.
- Fuel return line restricted.
- EVAP canister purge valve leak (when canister is full).
- Engine oil contamination.
cliftonfts
1983 - 2012 Ranger & B-Series
11-08-2009 02:07 PM
bigdaddyt
Modular V8 (4.6L, 5.4L)
01-14-2004 08:01 PM
