What to look for when buying a 2000 7.3 Powerstroke First Timer Here!
This weekend I'm going to look at a 2000 F-250 7.3 Powerstroke 4x4 XLT. It has 228k miles on it and the truck and engine are bone stock. The seller told me that the batteries and starter have just been replaced. Also, there is no rust on the oil pan which does not leak. Is there anything in specific I should look at on the engine and truck to determine if the truck is worn out or not? Also, what should I look for when test driving the truck? Please offer me any advice. This is my first time purchasing a diesel Ford pickup.
Thanks,
Jimmy
Thanks,
Jimmy
Since this truck is an automatic and a 2000 model, should I be worried about this?
01-13-5***TRANSMISSION - 4R100 - DELAYED OR NO 2ND GEAR - DIAGNOSTIC TROUBLE CODES P0781, P0755 AND/OR P0756 - VEHICLES EQUIPPED WITH 4R100 TRANSMISSION WITH TRANSMISSION BUILD DATES BETWEEN 7/27/2000 AND 3/23/2001 ONLY
For the OP. pull the intake boot off and look at the turbo inlet compressor wheel to make sure it's not damaged. Here's a thread with examples
https://www.ford-trucks.com/forums/1...od-or-bad.html
If you can, do a crank test to check compression. here's an example of good compression on a 6.0. Do the same on a 7.3, you just have to jump the start solenoid on a 7.3.
Here's an example of bad compression. start watching the video at about the 2:50 time point
One thing he does say that's good advice and this is for the OP, try and look at the truck cold. Don't let the seller have it warmed up for you when you get there. These things will hide problems sometimes when they're warm.
There is another f250 I will be looking at on Saturday this weekend. I think the truck is an early 99 model. I can't tell for sure though, are there any problems with the early 99s? This truck is in really good shape from what I can tell. Do the early 99s have forged rods? This one has the badge on the fender.
I Sure am enjoying the truck hunt! I don't know if I want an early 99 or not, I'm skeptical. Is it true that they don't have as much power as the later 7.3s? I'm not looking to build the engine up for more power or anything. This one that I'm going to look at Saturday has a date of 6-98 on it. Also it has the manual transfer case shifter instead of the dash mounted switch for 4wd.
No, it isn't true. Any changes between the e99s and the rest are not enough to make any noticeable difference in power.From what I remember the only changes made on the powertrain were a few things in the intake circuit. If it really bothered you, you could change those parts over to match the rest of the MYs but there is no reason to if the truck is healthy.
EDIT: If the truck has noticeably less power than other stock 7.3s it is because it almost certainly has an issue somewhere, not because it is an e99.
Unless you really want that Shift on the fly, autocking hub functionality of the ESOF system, you're not missing out on anything. The manual transfer case makes for much easier troubleshooting if you ever have 4x4 issues. At the same time, with manual 4x4 I doubt you would ever have much of an issue.
If you have the time and the patience, wait until you found the right truck that absolutely fits everything you want. I "settled" for a Super Cab, now I find myself lusting after Crew Cabs.
Baatzy
Baatzy
Baatzy
Baatzy
CCLB 2000 F 250 powerstroke 7.3 diesel
Early 99 1999 f250 powerstroke 7.3litre
