Help: Thermostat Installation
Replace themostat.
1. Disconnect battery
2. Remove air cleaner duct from throttle body
3. Drain collant and save
4. Follow upper radiator hose to the engine to thermostat
housing, on the front of the intake manifold
5. Loosen hose clamp and detach hose.
6. Remove bolts and detach housing cover.
7. Scraper off old gasket.
8. Install new thermostate in housing.
9. Torque bolts (you didn't list engine type)
10. Reattach hose and clamp
11. Refill system
12. Install air cleaner duct.
13. Attach battery and start engine, check for leaks.
