A/C condenser retrofit - Ford Truck Enthusiasts Forums
Old 03-18-2015, 07:47 PM
shaker666's Avatar
shaker666 shaker666 is offline
shaker666 is starting off with a positive reputation.
I'm converting my '79 Bronco with factory air from R12 to R134a. I'm replacing the stock York/Tecumseh compressor with a Seltec TM16HD and will need to run a high efficiency condenser to make the most out of the R134a. The only high efficiency units I can find are universal fit... does anyone know of a drop in replacement that's high efficiency designed for R134a?
New Condenser HoustonDave 1973 - 1979 F-100 & Larger F-Series Trucks 12 10-01-2015 04:17 PM
Air Conditioning Upgrades! thekingofcows 1973 - 1979 F-100 & Larger F-Series Trucks 16 06-25-2015 09:33 PM
'92, retrofitted to r134a problems... timbersteel Cooling, Heating, Ventilation & A/C 0 06-11-2015 09:44 AM
Larger condenser for 134a bren_tx 1987 - 1996 F150 & Larger F-Series Trucks 12 03-23-2010 10:44 AM
Do you need to change the TXV Valve with 134a conversion? fasthauler Cooling, Heating, Ventilation & A/C 2 07-28-2006 01:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
