Three reasons why Torklift turnbuckles outperform hold down straps
Whether securing a truck camper, recreational equipment or motorized vehicles, using hold down straps made from polyester webbing is a risky route. Depending on what you are towing or hauling in your truck bed or trailer, it’s critical to follow all safety precautions. Road safety is important, not only for yourself but for other drivers.
Torklift turnbuckles outperform hold-downs or ratchet straps due to the following:
1) Tie me down or lose me
Hold-down straps are prone to tangle easily and are quite a hassle to adjust. Once you’ve managed to get them on the vehicle, hold-down straps or ratchet straps easily fall off and are lost during transit. Have you encountered a truck on the highway with long ropes or hold-down straps flapping along in the wind? Did you switch lanes? The more movement, the looser and less secure the straps become. Loose straps are a good indication that the load is not safely secured.
When using a Torklift turnbuckle like the Original FastGun, securing a load becomes hassle-free.
The FastGun turnbuckle is the easiest turnbuckle to use because:
FastGun turnbuckle won’t tangle
There are many styles of turnbuckles available, although other applications may require tools and adjustment. If convenience is important to you, consider FastGun turnbuckles in any application that requires securing your valuable items.
2) Hold on tight
With strap tie downs or ratchet straps, there is no way to determine appropriate tension. Regardless the application (truck camper, trailer loads, etc.), the correct amount of tension is crucial to transport items safely. The likelihood of failing straps or lost loads is greatly increased by guessing tension. Safety should never be a guessing game and is much too hazardous.
To prevent failed hold-downs and unbearable pressure to tie down anchors, it’s essential to use a spring-loaded method. Transporting over uneven roads causes the tension on tie down straps to spike to levels several times the static tension. Ratchet straps or hold-downs also stretch when stressed due to sudden movement. Unfortunately they don’t stretch or compress back like a spring would. The spring design acts as a shock absorber, protecting any anchor points you are using.
Torklift International FastGun turnbuckles are:
The spring in FastGun turnbuckles allow some give when your vehicle encounters unfavorable road conditions. Depending on the application and desired tension, the FastGuns have the ability to apply up to 450 pounds of spring-loaded pressure.
3) You’re Busted
Hold-downs made from rope and polyester nylon often fray and rot. Avoid the possibility of busted straps by using a Torklift International FastGun turnbuckle. Its unwavering strength and durability come with Torklift’s legendary lifetime warranty.
FastGun turnbuckles are composed of:
Due to the durability of these materials, each Torklift FastGun turnbuckle boasts a pull down rating of 2,500 pounds.
The stainless steel composition helps protect from the effects of rust and corrosion. The FastGun is also available in finishes of stainless steel high impact powder coated bright white, grey and black. High impact powder coat helps to further protect the turnbuckles from the elements. The turnbuckles require little maintenance and are very easy to clean.
Scott from Colorado uses FastGun turnbuckles.
“I finally broke down and bought some FastGuns,” said Scott. “I have to tell you they are terrific. Well-made and engineered.”
When towing or hauling items in a trailer or truck bed, road safety is not an area we can afford to be careless. In most cases, hold-down straps or ratchet straps are insufficient in supporting loads while traveling.
Discover additional applications for turnbuckles and click here to learn more about the Torklift International FastGun turnbuckle.
See more at Three reasons why Torklift turnbuckles outperform hold down straps - Blog
- Once assembled, installs in just minutes
- Quick-disconnect handle for ease of use
- 100% tool free
- Length can be adjusted with a simple twist
- Lockable, so you know your load is secure (whether stationary or in transit)
2) Hold on tight
- Spring-loaded
- Equipped with the patented O-ring tension indicator to guarantee tension
3) You’re Busted
- 100 percent stainless steel
- Lever action handle made from aircraft grade aluminum
- Available in high impact powder coated finishes
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
07-27-2018 06:16 PM
Torklift Sheryl
05-17-2016 04:29 PM
Torklift Sheryl
04-09-2015 10:37 AM
Torklift Sheryl
03-17-2015 12:41 PM
Torklift Sheryl
03-11-2015 12:50 PM
