tune up an old 1993 F150 5.8L
So I know there's probably a lot of other post on here about tuning up a 5.8L but i haven't really been able to find what i'm looking for. I'd like to do some simple tune up to help breath some new life into my old ford.
I'd like to upgrade the ignition has anyone ever bought a kit like this one from summit racing? and is it recommended for a stock truck?
http://www.summitracing.com/int/part...rd/model/f-150
Would like any other tips to improve performance on a stock 5.8L with 180 000 miles on it, i was thinking replace vacuum lines i had an issue with one last year so i'm thinking just do them all.
Maybe improve exhaust again i just have stock exhaust and manifolds. I have a 24ft travel trailer that I haul 4 or 5 times a summer.
Also I think i should change fluids ie tranny, rear diff.
Any suggestions and advice would be appreciated
Posting here just to prove I tried to search the subject. Looking for part numbers for a good ignition coil and distributer cap for an overall upgrade. I have SMP 8.5 mm crap wires with cermic plug ends which I hate but will keep for the time being. I think I used the OE plug gap but was wondering what ya'll recomend. I learned from the six liter timeing upgrade that 5.8s should not have their timing advanced past the OE 10 degrees.
Copper is a better conductor than iridium or platinum. Therefore, it actually offers better performance. The more expensive iridium and platinum plugs last longer, but they sacrifice performance to gain that longevity. These engines were designed and tuned from the factory for basic copper plugs.
I ditched NGK iridiums for motorcraft coppers already myself. As an Engineer I assume Ford designed the engine for a particular plug type (the O.E. material). I keep whatever O.E. material for all my vehicles plugs. There were a lot of threads about some people having issues with different spark plug materials when I looked into it for this truck. I do wonder if high out put modules and larger wires might improve the performance of other plug materials in these older engines but thats a lot of varibles to gleem from threads here.
I used stock replacement coil and autolite copper plugs, and live wire(blue)wires, running 87 gas, 13-14* timing, the fbs forum actually has a big write up on the Sixliter (tuneup) named after the guy that did it, I've had a few mustangs and always did the Jacobs ignition upgrade, and plug gap size, but didnt go that radical, my mpg went from 9-10mpg to 11 sometimes 12 just city driving, and a/c no summer and no ping
Yes, digging further into the FSB from Sixliter i found the article explaining the differences between the 5.0 and 5.8 in regards to how they react to the timping bump. So I posted my questions wanting to know which High out point coils and what spark plug gap is recommended giving what parts are avaible 10 years later. I am also making improvements on an imperfect truck. Ideally changes are made to a perfect truck so you can determine what had a positive or negative effect.
dj delite
06-24-2014 11:48 AM
Skandocious
27
04-22-2007 07:29 PM
sweetsride
06-16-2005 08:41 AM
