Motor wiring harness question... Conaski??
I have a wiring harness question for my ford truck guys. Case Study: I have a 93 F350 cab chassis with a 351W and a ZF5 trans. To make a long story short, it sat for a long time and something (mouse?) ate up some of the motor harness wiring, so I just removed the whole harness from the fuse panel plug.
Now I know my truck a 351 Speed Density setup, Do I have to get another motor harness out of a 351 or can I get one out of a 302? Are all Speed Density trucks batch fire, 302 and 351? I was under the assumption that if I got another batch fire speed density harness it would work, no matter which size it was?
Someone please educate me correctly! Thankyou
Best bet is to find a similar year/engine/transmission truck as a donor. Not all year harnesses have the same pin-outs from what I understand.
My EVTM from Ford references wire colors and circuit numbers when it comes to the C101 connector. No pin-outs anywhere.
All Speed Density trucks use batch fire for the injectors.
GA_Forester
10-02-2014 08:55 PM
radramrod2
01-26-2005 10:33 AM
