98 Ranger CYL3 Spark Plug keeps burning out
Hi, just thought I'd join the forum to help out a friend with a tricky problem.
He has a '98 Ranger 4L that he bought used more than a year ago. The vehicle has a history of burning out the Cylinder 3 spark plug and the service garage keeps getting told by Ford Canada to just put in a copper plug.
This seems to be merely a way of delaying the problem, as it inevitably returns him to the garage with the same problem each time.
BTW, the plug is white when they pull it out. The last visit to the garage polled for errors and found Misfire on Cyl3 and O2 sensor. Rplaced plug and SES went away but returned a few minutes down the road from the garage.
Has anyone else had this problem?
Thanks a lot,
gonzo_guy
Thanks a lot,
gonzo_guy
Thanks for all the great ideas! FYI, here's some more details specific to some of the suggestions:
-Spark Plug Wires tested ok
-Injectors flushed
-Vacuum leak was the most thought of possibility. It was tested for compression and a 48 hour moistures test was done. Results were all good.
So, any other ideas? I find it odd that Ford Canada keeps telling the garage to use a copper plug in the 3rd cylinder. It's as if they've had this problem before and haven't solved it, rather, they've found a way of delaying the problem with a plug with a different temperature rating.
TIA,
Gonzo
-Injectors flushed
TIA,
Gonzo
GONZO86
02-02-2016 04:28 PM
dylan8427
01-17-2011 12:54 AM
wybuck
1983 - 2012 Ranger & B-Series
05-09-2003 12:36 AM
