sct livewire ts tuner on 6.0
I've installed the performance tune on my livewire ts tuner. When I get on it it feels like the truck can't keep up with the engine. Any ideas? The settings can be changed for alot of different settings, is the a certain setting anyone does to get the best performance out of truck. I also have 3 custom tunes I haven't picked out yet. Which tunes should I get? truck is for everyday driving to work nothing else. I have stock head studs so maybe tunes that won't blow my gasket. Thanks
Gearhead tunes, I run them on BOTH my trucks and couldn't be happier!
The shifting, power, fuel economy, idling, and even the starting can't be beat.
On the 7.3 I've run:
-SCT X2 set on Performance
-DP-Tuner (waste of money)
On the 6.0 I've run:
-Gearhead SRL+ and SRL Extreme
-Truck Source Diesel's Super Panty Dropper
-Quick Trick's Looney Wild
Gearhead tunes have by far been the best on my truck and I strongly recommend them.
Matt writes tunes for studded and non-studded trucks.
Hokiehivpi runs SRL on his '04 Excursion and he's only had the EGR deleted and the oil cooler swapped running stock headbolts.
BOLINJORDAN
06-23-2009 02:34 PM
SLMDLM
12-22-2008 08:11 PM
