Tie Downs for Truck Campers – Torklift International
True Frame Mounted Tie Downs by Torklift International incorporate four independent tie-down points that are engineered to fit tight and secure to your truck frame with no loss of ground clearance. Most applications do not require drilling, preventing potential damage to your truck bed/bumper and properly securing your camper. Unlike other bed-mounted tie downs that flex and sway with the movement of the truck bed, Torklift’s TRUE Frame-Mounted Tie Downs attach directly to your truck’s frame to maximize stability.
The most popular steel tie downs are now also available in military grade aluminum. Torklift’s aluminum Talon Tie Downs are 50% lighter than steel, precision crafted and powder coated featuring rust–free corrosion protection for life. Both the Steel Tie downs and the new Talon Tie downs are covered by our legendary lifetime warranty.
Torklift will warranty the frame of your truck and camper anchor points for the extent of the manufacturer warranty when you use any of their fully spring-loaded turnbuckles and frame-mounted tie downs. Inquire by email for warranty details.
- Fast, no-drill installations
- Best ride quality in the industry
- No loss of ground clearance
- Hidden when not in use
- Small truck applications
- Available in 100% military grade aluminum with rust free corrosion protection for life (Talons only)
- Legendary Lifetime Warranty
- Proudly made in the USA
Designs vary based on specific truck applications.
Find a retailer near you on our nationwide dealer network here:
Where to Buy
To learn more, contact Torklift International directly at support@torklift.com or 800-246-8132.
Visit us online at Torklift International | Truck Camper Tie Downs | Towing | Steps & Handrails | Suspension.
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
07-27-2018 06:16 PM
Torklift Sheryl
02-20-2018 06:50 PM
Torklift Sheryl
08-11-2016 06:36 PM
Torklift Sheryl
05-17-2016 04:29 PM
