73 F100 4.6 build
I aquired my great uncles 73 for free, and i aquired a running and driving 99 crown vic police intercepter for free plans are the 4.6 SOHC, trans, PCM and harness transplanted into the 73, full suspension and exhaust, lowered 2", 18's, body and factory color repaint, interior and then sold. With that said here some pics to catch up to current
Don't sell the crown vic yet! You mentioned you wanted to lower it. Swapping in the crown vic front suspension on these trucks is very popular. It lowers the truck, and it will handle better. Do a quick search, and a few build threads should pop up. I think there is even one with a 4.6 swap.
I do still plan on a CV suspension swap bronco, but on this peticular CV, the front suspension/k member isnt removable and is built into the frame as i had originally thought (i guess that came in the later years?)
I would rather find the bolt on subframe rather than work to try and "graft" these 2 frames together... So i got a guy willing to buy the front frame section for $100, that money can go towards a couple other builds i have cooking
That does beg a question tho... The F100 has a leaf sprung 9" in back with 3.25 gears, and the vic has an 8.8 (unknown gear) with coil suspension...
Now obviously i would rather have the coil suspension in back and most likely will end up doing that... But what axle do i use, the 9" or the 8.8?
