First truck - 1993 F-250
I picked up my first truck yesterday, it's a '93 F-250HD XLT. It's two wheel drive, has a 300l6 and a ZF 5 speed. First on the to do list is fix everything it needs before I start doing anything major. My plan is to drop the rear to be level with the front, freshen up the engine for some more power (she's a dog), and some 17x9s or 20x10s with street tires. Keep it clean and classy
Changed the oil and put a new radio in the truck today. That was fun laying in the slush under the truck, not.
One thing I've noticed about the truck is that every so often at idle it'll miss and shake the truck a little. It idles at just below 1000rpm which I don't think is right for when it's warmed up. Any idea what could cause all of that?
Thanks
Dom
Thanks
Dom
Thanks
Dom
Thanks
Dom
And the idle speed sounds fine, both of my trucks idle at about 800 once warmed up.
I also have the 5.8, and it idles just below that... maybe 650ish.
As for the miss, mine had a very bad miss when I first got it. It turned out to be a wiring issue caused by some hungry rodents (it sat for 4 years before I bought it). It took the shop a while to find it because it's not typical.
Didn't get the cap and rotor or fuel filter for the truck, but whoever did plugs and wires on the truck before didn't do too good of a job because I was able to take out a few with just my hand. Crazy. Either way the truck runs much better now.
Next on the list is front tires so I can get her inspected. I'm not sure if I should go with LT235/85r16 like the door says or if I should get LT265/75R16 which is what's already on it. Or do I even need LT tires? Some people say I do and others aren't sure.
