Can I install this temp sensor in Ford E40D test port?
Thanks! That is where I installed it this weekend! I did not know if the "nose" on the sensor would damage anything inside the transmission, so I got a 1/8 NPT male/male fitting and a 1/8 NPT female/female fitting, joined them together to make a M/F 1/8 NPT extension. I'm waiting for a radiator to come in so I can't fire it up and test it out yet.
Steve
Steve
An update I meant to post in this thread earlier: I got my radiator installed and was able to go for a test drive. My new dual temperature gauge works great, and provides temps for the engine coolant and transmission case. Went for a 20 minute interstate drive and engine temps topped out around 199F and the transmission around 183F.
The transmission temps were slower to come up than the coolant temps, so I suspect there is some lag in measuring off of the test port as opposed to, say, being inline with the transmission fluid outlet line. But this is for an RV and most of our driving is long-haul so I think this will do fine for giving us an idea of the overall transmission temperature. Previously there was no sensor at all so this is definitely an improvement!
Attachment 285027
Steve
Attachment 285027
Steve
Yup, it's this one:
I added a 1/8 NPT-to-1/8 NPT female-male adapter to the test port of the E40D transmission, so that the nose of the sensor would not hit anything inside the transmission.
I installed a new filler neck / thermostat housing on my 460 engine that "came" with a 3/8" NPT threaded hole:
However, the thing was evidently plated after drilling and tapping and so required re-tapping the 3/8 NPT hole. I put a 3/8 NPT-to-1/8 NPT male-female adapter in this hole for the sensor:
The instrument panel in that location of my 1990 E350 is mostly hollow in the dash frame (which is why the battery gauges are there ) - I had to remove a little bit of material to allow clearance for the gauge behind the panel. Originally I mounted the gauge flat/flush with the panel face, but the gauge includes an angled bezel to allow the pod to be angled towards the driver, so I did that to make it easier to view.
I'd like to find pod holders for the driver pillar post but they don't seem to be available for 1990.
Yes, I realize that the transmission runs cooler than the engine, but what I was trying to say is that the engine sensor, being immersed in the coolant directly, runs up in temperature faster than the transmission sensor does. The engine sensor gets up to max temperature within 5 minutes of 60MPH running. The transmission doesn't max out until about 20 minutes of running. I suspect you'd get a faster gauge response if you were measuring the transmission fluid output directly. And if you start to overheat the transmission I suspect there would be some lag before you would know it. Still, it is a wet port, and it's super convenient to use, and the transmission engineer says it's the best place for it, so I'm happy with it.
Steve
Steve
The test port is an accurate reading, the transmission doesn't heat up as quick as the engine that's why the temp is lower.
For any heat-generating machine with coolant, barring actual sensors embedded in the heat-generating part of the machine, the coolant exit temperature is going to give you the fastest reading of temperature changes in the machine. Practically, this probably doesn't matter.
Steve
I my opinion the best place for the most accurate temps is in the pan
Steve
I would think the pan would be where the cooled fluid is deposited on return to the transmission, to be picked up by the pump, and so reading the temperature there would give you the fluid temperature at its coolest, except from the line just before it enters the transmission.
mattri
03-21-2024 03:49 PM
DRRXR
03-02-2009 11:17 AM
JasonL
12-07-2003 06:13 AM
