Loose Shifter, Can't Quite Get All Gears - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 02-14-2016, 04:59 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
post #5, part #56
there are 2 of them, side by side. Study the post, then take your torx driver out there and go fix it
Old 02-26-2016, 10:06 PM
kincfu
kincfu is offline
kincfu is starting off with a positive reputation.
Hello,
What is the torque on the bolt?
Thanks.
Kin
Old 07-10-2018, 09:18 PM
Jamsbandit
Jamsbandit is offline
Jamsbandit is starting off with a positive reputation.
Originally Posted by blageurt View Post
I know where that screw goes but I would need the exploded view to show you ...I can't explain it here....
Wrong post
Old 07-10-2018, 09:21 PM
Jamsbandit
Originally Posted by PStruwing View Post
I had to tighten both # 56 screws on mine a bit back for same issue. No major dis-assembly required. Just a massage after due to contorting to get to the bolts.
I used Loctite Red on them to be sure they never come out again!
How did you get to the bolts to tighten them? I can't find a way to get my hands back in there. It looks like I'll have to take the whole dash apart.
Old 07-10-2018, 09:30 PM
blageurt's Avatar
blageurt
blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
I used a manual "L" shaped T30 last time ...I used the Rachet 1/4 drive before.... A telescopic Mirror Helps......I have done it so many times I do it by feel .Hope this helps... Torque should be around 10-15 lb/ft....IIRCC.....
Old 07-10-2018, 09:37 PM
Jamsbandit
Thanks for the fast response. I'll get an L shaped T-30 and give it a shot. Didn't know they made them. Much appreciated.
Old 07-10-2018, 09:42 PM
PStruwing's Avatar
PStruwing
PStruwing is offline
PStruwing is gaining momentum as a positive member of FTE.
What Blageurt said! I used a 1/4 drive. And make sure to use a thread locker.....
Old 07-10-2018, 09:45 PM
blageurt's Avatar
blageurt
blageurt is offline
I bought the set …..It's like a Allen Key set …. but it is all Torx… I also have All the sockets but as you know , not much room up there....good luck
Stewart_H
06-23-2018 06:08 PM
phillee8286
12-19-2017 12:41 PM
phillee8286
12-17-2017 11:40 PM
HMS
1999 to 2016 Super Duty
10-23-2017 04:29 PM
x94ray
02-23-2017 03:49 PM
Quick Reply: Loose Shifter, Can't Quite Get All Gears
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
