has anyone put a 460 into an old F5
I spent a fair bit of time working on shoehorning a Ford/IH 6.9 (very similar size class) into my F5. Ran into too many problems getting clearance between the headers and frame rails, steering box and pedals. Might have been doable if I was willing to cut apart the cab and doghouse it to sit the engine higher, but I opted to go for an inline diesel instead.
I put one in my f1. Same idea basically, but put a mustang rack in so there is probably more clearance for the steering. I used the sanderson headers that are made to fit a 460 into an f1. I did have to move the radiator forward. You'll either have to modify the firewall, or move the radiator. I don't think youll be able to get it in there without moving something.
If you look at the last picture, the rear radiator saddle of that double saddle that i made is mounted in the 6 cylinder position ( the picture where it is touching the water pump in in the 6 cylinder position.). With the beam axle, you might be able to get the engine lower than I could which would let you move the engine back further without cutting up the firewall.
Englishbob
09-19-2011 10:20 PM
revolutionunited
07-23-2011 10:23 PM
