ford 300 the motor that cant be killed....supposedly
Hopefully you can help me out, and not have me going backwards. 92 f-150 4.9 I6
Truck would not start. Would try and fire up but refused. Pulled spout connector and now she starts. But idles really high and blows thick white smoke. Enough to cover the block in under 5 minutes. Uses no coolant though. The air bypass solenoid is gone as well as the charcoal canister solenoid. I tried to re-teach the idle but I can't get it to. I've had the batteries off this thing so many times trying to get it to run. I am going to go to the scrap yard and pull solenoids to put vacuum setup back to normal. But in the mean time WHY IS MY TRUCK SMOKING SO MUCH. And it smells like gas too. Any ideas?
White smoke is typically water. Removing the spout connector locks in 10 degrees of timing.
Was it running normal before this? Did anything happen? High idle could be a vacuum leak.
Excessively rich would emit black smoke, oil consumption would be blue-ish. Water it white. ATF is a whitish blue but I don't know if there's a vacuum modulator. A friend had a Chebby that blew the modulator and it was like a cheesy spy flick the smoke was so thick...
It comes out super thick at the muffler since it busted. But once it leaves the underside of the truck it does dissipate some. But keep in mind its 30 degrees here so I wouldn't be surprised that its sticking around for so long. Now when I bought an s-10 a few years back I got a bottle of blue devil head gasket sealer. Guaranteed to work. Would it be worth running it through? If it doesn't work I'm really just out some time not money. Has anyone ever tried it? And when I was trying to get it to run in the first place the plug in cylinder #5 had oil on it so I'm thinking the rings are out too. But I thought these were 500,000 mile motors? Its got 200,000 on it right now.
Before you start your truck again, wipe your finger inside the tailpipe.
If the soot is:
Finally, there are a lot of ways to perform a compression test. Typical $20 tester will tell you a lot (get you started), but may not be sufficient to tell you everything. Leak down tester is more expensive and requires a compressor. Good subject to read up about online. Youtube may help.
If the soot is:
- Normal - Dry, grayish powdery, mostly rinses off with water only
- Leaking coolant into combustion chamber - Wet, slippery, smells sweet, rinses off without soap.
- Oil burning - Wet, slippery, dark, need soap to wash off
Never seen that, but you must have. Makes sense. Power brakes would probably be nil if the vacuum booster were that bad.
do a compression test. and look at each spark plug. and while it's running you can spray some wd 40 or carb cleaner along the outside of the head where it bolts to the block. if the head gasket is blown towards the outside edge. i dunno where the heck the water jackets are on these things. if i ever get a 300ci i'm doing a copper head gasket and converting it to a carb. and getting rid of all the electronic whatsis.
