12volt wiper for 48F1
The.'48-50 units are located behind the dash, above the speedometer. They came stock with only one wiper with a second controlled by a long arm as an option. Only operated by vacuum. The '51-52 had the motor, either electric or vacuum, located behind the dash but centered. The stock radios were mounted lower in the dash. I think all '51-52 had dual wiper units standard.
Vacuum wiper motor Trico rebuild kits use to be readily available. A company that rebuilds wiper motors and use to sell kits (new paddle and gaskets) is Ficken in Babylon NY. I have a feeling that they no longer sell the kits but still rebuild. Careful disassemble, (the gaskets are fragile) cleaning and a relube may work for you.
"The Wiperman" (Ficken) will not sell parts. Just as well, I have called him twice over the last 20 years and he's so rude I would hate to give him any business. From the units I've disassembled, as long as the switching mechanism is OK, making a new seal for the piston looks do-able.
There aren't many parts in the wiper body. I took mine apart, cleaned carefully and "greased" with very small amount of vaseline and it works as well as the day it was new.
Keep in mind it has the hookup for the vacuum and an "exhaust" port. The second one was a little puzzling until I had it working and heard the hissing.
center like a 51-52?
Also a guy on Utube saying the best fix is ATF squirted in the vac port of
the motor while hand moving the wiper arm to suck the oil in there to swell
and lube the felts etc..
Ross,
The last time I dealt with them (bought parts) was in the 80's at Hershey. Is there another source that anyone knows about?
#28
This search for parts comes up all the time on multiple forums, and the conclusion always is that there are a few NOS rebuild kits laying on shelves, but very hard to find. I'm really surprised Trico or someone like Ficken doesn't repro at least the piston seal, it would be easy, and the market large.
#29
If it's the stock vacuum motor, it should be directly behind the instrument panel. I'm thinking yours might night be stock if it's jammed against the radio.
#30
