Hey all,
So I got the front end on my 50 F3 all done. Converted to a disc brake system from CPP. I found that when I turn to the left at full lock, the tires rub against the pitman arm. Has anyone else had this happen? Did you use spacers to push the wheels out for more clearance?
Can't answer your question, but I wonder what you think of the kit? Can't decide if I want to go that route on mine or not. And what did you do for a master cyl?
Pat
Pat
The CPP kit is great and really easy to install. Took me about 3 hours. I used a 1975 E150 Ford van booster and master cyl and mounted it on the firewall. i used some 10 inch by 10 inch plate on each side of the firewall for reinforcement.
Way too much missing info to answer: undropped axle? steel or aluminum wheels? wheel diameter and offset? wheel width? tire size?
I'd expect the best solution is 544tess's advice.
Sorry Ax....here is the info I have. The wheels are stock 1990 E150 steel van wheels. I am not sure of the offset right now because the truck is not in my garage as we speak, but if I had to guess I would say 2 inches maybe. I believe the rim width is 6 inches (stock). The tire and wheel combo are stock 225 75R 15. The axle is stock but I do have the Posies super slide drop spring up front which is supposed to drop it 3 inches over the stock spring pack. My thought is that even the small offset that is probably present on the stock wheels is more than what the original wheels had and that is just enough to make contact with the pitman arm on a full left lock turn.
I had the same problem as a result of the wheel offset , I went with billet spacers .
Can you tell me what brand and how thick they are? I am looking at some from Speedway Motors that are 1.25" thick. They call them "adapters" even though they are the same 5.5 to 5.5 bolt pattern. I used some Spidertrax on my 2007 Jeep Rubicon years ago when I went with larger tires because of frame rub and never had a problem with them.
I would first stack washers on the lugs and see how much it takes to give adequate clearance. You can buy inexpensive 1/4" universal aluminum spacers that slip over the lugs at most auto parts stores if that is enough, and you can use the original lug nuts as long as the lugs extend out at least one thread beyond the nuts. I use them on the Solstice when racing as allowed in the rules just to give the car 1/2" wider tread width. When racing at national level you use even the smallest advantages allowed.
That's a good idea. I think I have some extra round aluminum spacers that were used to space the t-case when I did the lift on that Jeep. I will use them to see how far out I need to go. I don't think I will need that much. I will need to use some on the rear as well since the tires ride a little too close to the fender wells for my comfort. I went with a 5 leaf spring pack and '70 F-100 9 inch rear end with the same '90 Ford van wheels and I have about 1/2" to 3/4" of clearance. If I ever hit a deep dip in the road that causes the sidewall to deflect, it may come in contact and scrub off some of the tire or make a racket.
Here is a side shot...although from a distance, but I think I could use some pretty hefty spacing to put the tires out toward the fender lip.
Reason: added pic
I guess I went with the easy solution. I made a stop from angle iron with a gusset and adjusted it so that it would stop the pitman arm from moving far enough to contact the tire. Didn't really decrease my turning radius in that direction by much so it works for me.
