5.0 Coyote Tapping/ Ticking/ Knocking
#406
Knock on wood, my remain block has not had the issue return.
Glad you were able to catch while still in warranty. Will be interested to see what they do for 3k worth of work. The only way to fix Is replacement short block at a minimum. Many are getting complete remain units and the repair bill is around 9k.
Just spoke to the dealership shop where I have the truck. They are looking at the 4 timing chains & tensioners that feed the camshaft phasers as being the possible issue, though they won't know until they dig in.
The service guy did mention long block replacement, but said usually that's on engines that are at around 90k mi and haven't been properly maintained. He said he hasn't seen a short block replacement come through his shop for this yet.
All repairs are being run up the flag pole to Ford and then he follows their directives. Luckily, this is all covered under my 5yr/60k power train warranty, so at least I'll have the chance to see if any repair they make truly sticks.
But meanwhile I'll be sitting without my truck for at least 2 weeks. Good thing I have my '95 Club Wagon to drive around!
#407
#408
I've been watching this post for a long time ......... probably since right after buying my 2012 5.0 Lariat back in April 2015 (with 43 K miles).
I'm now at 70K miles and would say that my truck runs/sounds the same now as it did when I bought it in 2015. While changing my oil yesterday, I took a video - would like to hear what people think - does my engine sound 'normal' ? Sound like I have a problem ?
Thanks.
Thanks.
#409
Glad you were able to catch while still in warranty. Will be interested to see what they do for 3k worth of work. The only way to fix Is replacement short block at a minimum. Many are getting complete reman units and the repair bill is around 9k.
Found visible scoring on camshaft and main journals
Timing chains have lost their prime
There is a lubrication problem.
Very uncommon for an engine with this low mileage.
Dealership is recommending and asking for a remanufactured engine from Ford and hoping they will authorize.
No matter how this slices, I'll be without the truck for an aggregate of probably a month once all said and done.
Really hoping for the reman. Seems like the only solution that will give me a shot at not having problems crop up later.
#411
Thanks.
Thanks.
OK - update from dealership after opening it up:
Thanks
#412
Though I can't say for sure, it doesn't sound like that "tapping" sound I was getting. Take a listen: https://www.ford-trucks.com/forums/1...l#post17107595
Shoot, sorry to hear. I would keep pushing for the reman long block if you can. Keep us posted.
What happened when your engine failed? Did it leave you stranded and failed to start? Just interested in hearing what the failure mode is like for this issue.
Thanks
Thanks
This engine was babied by me. Never towed. Never abused. Always maintained. Not modified. Most maintenance was done at Ford Dealership. A flaw in the block meant it would die prematurely. I wish it would have happened under warranty.
#413
#414
#415
I have yet to see anyone with a '14 post up that they had this issue and needed a new motor, though there are far more trucks out there than forum users.
#416
I suppose it's hard to say. I thought my '13 was in the clear but it was not. I can tell you that based on the part number of the reman unit they installed it is a '14 block. So far, things have been good with the new motor.
I wish all happy, trouble free motoring and a safe Holiday Season.
#417
Truck is back w/ new engine...
and a new starter motor because that failed while in their hands at the dealership.
It's been gone since 11/3... so dang near 6 weeks.
Sounds very smooth and quiet so far.
Hope this is the last of this saga and I can just enjoy it now.
Thanks a ton to this thread for educating me and giving me some hope of it being fixed.
#418
I bought my 2013 with 93k on the clock right before Christmas. I never heard anything until a week later after warming it up when the weather turned cold here. Walked up to it and heard the tapping. It is pretty constant once the truck is warm now. My ONLY concern is if it is BAD enough for the dealer to do anything about it. I have an extended warranty that my CU sells and is one of the better ones out there according to their BBB rating. Here is the video I took just a while ago. I plan on taking it in on MLK day since I have that day off. I just want the dealer to hear it and determine if they are going to do something or not before I give them the deductible and leave it with them. It will be Southwest Ford in a Weatherford, TX. Hopefully they will be good to me, it’s a BIG dealer here.
#419
https://youtu.be/ZLDyJQmUBPA
#420
That’s what I was hoping, that I wasn’t the only one hearing it. I’ll keep you all updated, I have a feeling that since I’m not dealing Ford on the warranty then it might go a little easier. Service should be able to sell the warranty company on it easier than the manufacturer......I just want to get this resolved before I do anything to the truck. I’m wanting to do a full exhaust and stuff but don’t want to do any of that with a major engine issue and give ANYONE reason to deny a warranty claim...
