5.0 Coyote Tapping/ Ticking/ Knocking - Page 30 - Ford Truck Enthusiasts Forums
  #436
Old 01-14-2018, 05:45 AM
maytag906's Avatar
maytag906 maytag906 is offline
maytag906 is gaining momentum as a positive member of FTE.
My 2011 5.0 doesn't have the noise. I use Pennzoil synthetic blend 5W30, about 10,000 between changes, Motorcraft filter. It now has 69,000 miles on it.
  #437
Old 01-14-2018, 05:45 PM
tex1g2007 tex1g2007 is offline
tex1g2007 is starting off with a positive reputation.
5w-20 Motorcraft Full synthetic since new. Always changed at dealership since I got free oil changes included when I bought the truck.
  #438
Old Yesterday, 10:21 AM
WXboy's Avatar
WXboy WXboy is offline
WXboy has a good reputation on FTE.WXboy has a good reputation on FTE.
Quote:
Originally Posted by Robbgt View Post
MC synthetic blend 5W-20 as the manual recommends. Oil and MC filter every 5k. The issue is a manufacturing defect in the block so a thicker oil might band aid it for a bit bit won't fix the problem.
Yeah it's just strange how some blocks had this defect and most didn't. Presumably they all came down the same assembly line and went through the same QC. Just makes a guy wonder if there isn't something else that's actually the root of the issue.
  #439
Old Yesterday, 10:42 AM
eriebasin eriebasin is offline
eriebasin is starting off with a positive reputation.
I use Royal Purple Full Synthetic, 5w20, with a Motorcraft filter. I do use the OLM to tell me when to change; I get about 10,000 miles between changes. I have a trusted local mechanic who does my oil changes; I have been with this mechanic for nearly 15 years. The dealer does all the warranty work of course. I believe the truck came with synthetic blend in it; I followed a break-in procedure of: 1,000 miles before I towed, of not using the cruise, varied speed, no WOT demands on the engine, etc. I changed the first oil out at 5,000 miles. Mine also came with 2 free oil changes; I paid to upgrade to full synthetic. Since it was mostly free, I did the next change at 5,000 also. From then on I followed the OLM and continued with full synthetic; I switched to my local mechanic/Royal Purple from Motorcraft Full Synthetic/Ford dealer after my last free change. I've been using motorcraft filters with the Royal Purple oil. I doubt all this saved me from the failure others are experiencing though. Apparently there are some bad engines out there it would seem. I hope it's not a fundamental design flaw present in all. I also hope Ford makes this right with replacement.
F-250 Brake Pads Nutbuster 1999 to 2016 Super Duty 17 11-30-2017 11:41 AM
V10 60,000 mile. What to service??? 48bonus 1999 to 2016 Super Duty 3 11-13-2017 11:15 AM
Spark plugs part of 60000 mile service? Northroadak 2009 - 2014 F150 6 08-03-2017 08:51 AM
60,000 mile service. PrinceValium 2009 - 2014 F150 18 05-10-2017 11:12 PM
2011 F-150 Ecoboost Cold Start Grinding Noise - Timing Chain huntnrig 2009 - 2014 F150 183 01-25-2017 09:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
