Voltage problems!!!
Old Feb 20, 2015 | 02:32 PM
Derekholt's Avatar
Derekholt
Voltage problems!!!
I have a 2006 f250. Had new batteries and new alternator put in less than a year ago. The voltage that is being put out fluctuates between 12.5v-15+ Volts. Any idea on what needs to be fixed? The battery light will flicker on and off at some times and sometimes when it's running between 13.3-13.8 volts the battery light stays on.
Old Feb 20, 2015 | 02:46 PM
RideDiesel88's Avatar
RideDiesel88
Battery like means charging system problems. Why did you replace your alt and batteries? Sounds like a faulty alternator. I wouldn't like to see 15+. that usually means bad regulator in alternator. And any AC current ouput means bad diodes in alternator. Disconnect batteries and check open circuit state of charge. 12.6 is 100% 12.4 is 75%. Batteries don't like cold so it might take a while for voltage to stabilize above 13.5 after starting engine. Don't turn a load on until it does. But voltage should be 13.5-14.5 while driving
Old Feb 20, 2015 | 05:02 PM
Derekholt's Avatar
Derekholt
Thank you I will check it out! The alternator went bad last year around June and a few months later I had my truck bullet proofed and they put new batteries in then.
Old Feb 22, 2015 | 03:01 AM
Yahiko's Avatar
Yahiko
Check the plug on the alternator. Sound like the battery sense line is
not making contact like it should be or if at all.
Have a look here >>> https://www.ford-trucks.com/forums/1...or-wiring.html
Sean
Calheader
Nov 19, 2014 02:30 PM
tlbranth
Nov 16, 2014 01:23 PM
garydmundy
Nov 25, 2013 09:45 AM
Fluid Power
Jul 8, 2010 01:56 PM
Builder123
1997 - 2003 F150
24
May 16, 2009 06:56 PM
