Ball Joints
Old Feb 19, 2015 | 12:15 PM
Raleigh234's Avatar
Raleigh234
Ball Joints
I lifted the front of the truck up today because when steering, it'll pop occasionally, so I wanted to check to make sure they haven't been worn out. I lifted the front passenger wheel, and the top joint didn't budge, but when I grabbed the bottom of the tire and lifted up, the entire joint shifted about 1/4 inch around. I've done this repair before, on a 2004 Super Duty, but I've never seen this amount of play in a joint ever. Are they supposed to move that much or do I need to get it replaced? As a precaution, the truck is not going to move. It's not going to be driven until I figure this out. It's a 1997 Ford F-350, 84k miles.
Tie rods are fine, tires aren't worn bad (they have less than 30k miles on them) but that joint moves a lot. Due to where it is parked, I can't check the driver's side. I'm at school and I live on campus so there is someone parked next to it a little close.
Old Feb 19, 2015 | 01:34 PM
farmert's Avatar
farmert
If the ball joint moved that much it needs replaced. You should not get any movement from the joints except the normal pivot as when steering. If it was the tire moving up and down, It could be the wheel bearing is loose or shot, which needs attention also.
Old Feb 19, 2015 | 06:32 PM
Raleigh234's Avatar
Raleigh234
When buying the bearings, how good is Masterpro? I know Moog is good, but Masterpro is cheaper. It's got a limited lifetime warranty, but I don't know anything about it
Old Feb 19, 2015 | 06:47 PM
stainlessstroker95's Avatar
stainlessstroker95
Xrf chassis seems to be a good brand past couple years.
Old Feb 19, 2015 | 07:17 PM
MI02SVT's Avatar
MI02SVT
Go on bronco graveyard they have oem Dana/spicer ball joints 70 bucks for upper and lower set and timken bearings
wrdabney
Feb 11, 2010 07:17 PM
jeeptroll
May 8, 2007 09:20 PM
98 Ranger XLT
1983 - 2012 Ranger & B-Series
Jan 24, 2006 11:45 PM
gyronaut2b
Apr 14, 2005 09:57 PM
200solomiles
Feb 12, 2005 10:48 AM
