Oil in the valley, why?
on
Simple Green and low pressure water. Avoid electrical components with both. Then put some rags under each of the areas that AllaboutMPG noted and wrap the HPOP fittings with a paper towel if you can. Then crank it up, see what happens. If nothing, then drive it for a short distance and check again.
Stick your finger in it
One other thought, are you positive it's oil? The fuel bowls on these motors are known to leak and that fuel mixed with the crud in the valley can look like oil at first glance. Watch the very back and bottom of the fuel bowl with the motor running and make sure you don't have a drip there. Get a whiff of the stuff in the valley and see if you smell diesel.
Here's a link to Guzzle's Diesel o-Rings.
High Pressure Oil Pump Repair Parts
Here's a link to Riffraff Diesel
Ford - 99-03 Super Duty 7.3L - O-rings - High Pressure Oil Pump - Riffraff Diesel Performance
Both companies are great to deal with. First things first though, have you determined where the leak is coming from?
on
Okay so I fixed the oil rail plug leak. Removed it and put a new oring on it, reinstalled, got the truck started after some cranking. But now even after running a couple times, it still takes excessive cranking to start. This thing usually starts right up.
Could The IPR valve have gone bad suddenly like that?
I'm thinking maybe I just need to take it out and drive it like I stole it to get the air out of it. Maybe?
